Lost Black "MINI" circle on hood emblem
Old 02-11-2016, 04:03 PM
Promius's Avatar
Promius
Promius is offline
Hey guys. My MINI lost the black circle inside the hood emblem today. During a car wash. The chrome emblem is fine, just the black circle "MINI" is missing. Any way to replace that part without getting an entire new emblem?
Thanks!
its an R56 if that matters
Old 02-11-2016, 04:08 PM
Promius's Avatar
Promius
Promius is offline
My friend just owned me big time after I told him about my emblem problem :\
Old 02-12-2016, 08:17 AM
ECSTuning is online now
Received 1,965 Likes on 1,765 Posts
Been there before: https://www.northamericanmotoring.co...e-is-gone.html
Here is the rear emblem. It comes off with a heat gun or hair dryer and then you can use some dental floss to get under line. Use blue painter tape to make off the edges where the old one is, before you take it off , then plead and stick on the new one.
MINI Cooper Rear Trunk Emblem R50 R52 R53 , R56 R57
http://www.ecstuning.com/Search/SiteSearch/51147026186/
Otherwise if you like to replace the center and want to take the time to fit one in one of the center cap sticker off of the wheel and try to fit it to the wings emblem, the emblem is smaller then center caps sticker ~ 50mm (36136758687) and the wings MINI center ( 51147026186) sticker is about ~ 45mm in size. You could cut it to fit for something custom. Of course the MINI lgog should fit, but wont have the ring design. So it would take some craft and cutting.
MINI Logo Center Cap Sticker
http://www.ecstuning.com/Search/SiteSearch/36136758687/
Old 02-12-2016, 09:35 AM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
Vendor
Thanks!
The MINI Hood emblem is HERE. There is no separate part number for the center sticker unfortunately. If you have a friend or know someone that has a vinyl machine, they could easily make a new one with a vector file though.
888.280.7799 | 6am - 5pm PST
Old 02-12-2016, 02:06 PM
bcriverjunky's Avatar
bcriverjunky
bcriverjunky is offline
Would be nice if just the stickers were available cause I would like to powder coat my wings black.
Old 02-12-2016, 02:10 PM
The discs are you best bet. But getting a new emblem helps , mine had the wings chipping when I changed it.
Plus you can put a pin on the back of your old one and pretend your a Pilot when you put it on your jacket.
Old 03-05-2018, 05:37 AM
ericwestby's Avatar
ericwestby
ericwestby is offline
Reviving this thread because the same thing happened to me, also after a blizzard. Mine is a 2005 R50, so I believe this is the correct part:
https://www.pelicanparts.com/More_In...rter=date_new#
Unfortunately I can't quite figure out how to replace it. As with the original poster, only the black enamel decal is missing, but I'm happy to replace the entire emblem to get a pristine look. Can someone point me to instructions on exactly how to do it? Folks have indicated that it "just sticks on," but there appear to be posts on the reverse, so I'm assuming I need to access the underside of the hood to get at the old one?
Thanks!
Last edited by ericwestby; 03-05-2018 at 06:09 AM. Reason: fixed a couple of errors
Old 03-06-2018, 03:46 PM
isamin's Avatar
isamin
isamin is offline
Heat area slightly with a hair dryer and then use a piece of fishing line under an edge and saw to and fro (not back & forth). Lift piece revealing 2 pegs. Use body tape to hold.
Go out and drive 90 mph for 45 secs. then report your results.
ISAMIN
ericwestby (03-08-2018)
Old 03-07-2018, 07:36 AM
Thanks!
Lots of info here on the R50/R52 Cooper ( NON S ) hood and trunk logo. Part number 51147026184 is the front one for you.
https://www.northamericanmotoring.co...i-emblems.html
Old 03-08-2018, 01:40 PM
ericwestby's Avatar
ericwestby
Thanks all! Unfortunately I'm in Massachusetts -- and my MINI is parked outside, so a hair dryer someone suggested isn't an option. Maybe after my next commute the hood will be warm enough to get it off cleanly.
Old 03-13-2018, 03:57 PM
ericwestby's Avatar
ericwestby
Success! And I even got it on in time for our insane March blizzard. Thanks again for your help. If this emblem lasts me another 13 years, I'll consider it $40 well spent.
Old 03-14-2018, 05:13 AM
Thats great, much better!
05-09-2017 12:35 PM
R53NaMini
01-25-2016 04:04 PM
01-19-2016 11:38 AM
zkrpS
01-19-2016 06:18 AM
01-15-2016 03:56 PM
Quick Reply: Lost Black "MINI" circle on hood emblem
