08 R56 Non S to S Swap
Old Jan 12, 2014 | 08:03 AM
  #26
NovMINI's Avatar
NovMINI
Here it is... Runs and drives great!
Attached Thumbnails 08 R56 Non S to  S Swap-forumrunner_20140112_110225.jpg   08 R56 Non S to  S Swap-forumrunner_20140112_110243.jpg
Old Jan 12, 2014 | 09:10 AM
  #27
Ian Landesman's Avatar
Ian Landesman
Why'd you swap bumpers? I thought I saw the white one on before.
Old Jan 12, 2014 | 09:25 AM
  #28
yesti's Avatar
yesti
Great job! Glad it all worked out
Old Jan 12, 2014 | 11:03 AM
  #29
NovMINI's Avatar
NovMINI
White one was on before the swap but the non s front end does not have the ability to hold the intercooler for the s ... I'm sure with lots if modification you could but I have 20 hours on the clock for this swap so I was going more towards speed than ingenuity.
It will be painted white Lol
Old Jan 12, 2014 | 11:04 AM
  #30
NovMINI's Avatar
NovMINI
Thanks! It was an awesome experience
Old Jan 12, 2014 | 11:09 AM
  #31
NovMINI's Avatar
NovMINI
Originally Posted by zrickety
5k to build an S is a bargain, I'll have to keep my eyes peeled for deals like that.
Just check out Auto salvage yards,
Look for a car that has been T-boned... It will make it a lot easier to get what you need from the car for the swap.
Old Jan 12, 2014 | 11:48 AM
  #32
NovMINI's Avatar
NovMINI
What you need to convert a non s to s:
mini cooper S front end
S Engine and transmission
DME(ECU)
Evap line and fuel line, only the first section of piping in the engine bay.
Battery from the s was 70ah versus 55ah in the base so I swapped that
At this point the car would crank and not start... All the mechanical parts took me 14 hours... The last six were spend taking the interior of the s apart trying to find all the computers.
You will need to swap the CAS, which is the key recognition system for the car and allows it to start. It also allows for the use of all the added options in the car... Like auto wipers and auto on headlights.
This unit is under the dash on the driver side... I believe it would be on the driver side in the UK as well as in always on the driver side.
I took the bcm from the s but I don't think it was necessary, I'm going to swap it back to the previous computer just to see if everything still works. This computer is located under the steering wheel.
The foot well module does not have to be swapped, if you do make sure the windows work before you button up... Mine worked in opposite directions and half an inch at a time.
And neither does the speedo or tach... If you can and you want to swap the tach and speedo its easy while you have everything apart so go for it. Make sure you can swap the head unit... Meaning the audio system and inputs need to be the same.
I already had an s bumper and s exhaust so I didn't have to deal with that portion of the swap... But all you need from the salvage car is the rear bumper and exhaust mounts.... Pull the heat shielding out you don't need it.
Important note, if you have an automatic... Don't swap to manual. I'm sure its possible but probably with about 10 hours more work.
Non s hood will have to be fitted... The s hood is different not only because of the scoop but the frame itself is entirely different... I used a hammer to get out most the kinks fine adjustment still needed.
If you have a steering wheel lock and the donor car does not you will need to swap the steering wheel check this when you're swapping the CAS. Its very easy to do will only take about 30 minutes.
Old Jan 20, 2014 | 07:03 PM
  #33
NovMINI's Avatar
NovMINI
Some pics of the half was finished Frankenstein. Its done very well Indiana to Tennessee and back twice. Not a single hick up!
Old Mar 18, 2014 | 01:54 PM
  #34
saliac91's Avatar
saliac91
Hello, I am an Italian user. I want to try to do the swap. send me more photos in private? and a list of components? thanks
Old Mar 18, 2014 | 02:10 PM
  #35
Saltysalt's Avatar
Saltysalt
nice job dude!
i wish i saw this at the beginning!
i might have to do this just for ***** and giggles!
Old Mar 18, 2014 | 02:40 PM
  #36
NovMINI's Avatar
NovMINI
Originally Posted by Saltysalt
nice job dude!
Hell yeah! And thanks!
Just watch out for pesky timing chain issues. I got a motor that's effected and I will be replacing it this coming week, it is a recall item.
So a proper disclaimer: you will void the warranty if you do this swap! All warranty and recall items will have to be repaired on your own dollar or by yourself like me.
Old Mar 18, 2014 | 02:55 PM
  #37
DneprDave's Avatar
DneprDave
Meh, just like every other car, I've ever had.
My MINI is the first car I've ever had with a warranty
Dave
Old Mar 18, 2014 | 02:59 PM
  #38
NovMINI's Avatar
NovMINI
Dave
So nothing to worry about haha
Just annoying when you can get something done for free by the dealer and they have an excuse not to do it.
Old Mar 25, 2021 | 02:54 AM
  #39
PeaceVam's Avatar
PeaceVam
God bless the author
Priceless thread!
GT350
Oct 13, 2021 11:26 AM
thewizz
May 4, 2013 03:19 PM
DixonL2
Apr 25, 2011 05:45 AM
mistro
Apr 27, 2008 08:33 PM
