Stange window/sunroof opening on their own??
I went into work this morning and and ended up coming back to my Clubman S about 30 minutes later to find both windows down and the sunroofs open.
Is there some type of auto command that I could have inadvertently executed that caused this...or is this a clinch I need to have checked out?
If the unlock button on your fob is held down then the windows will roll down then the sunroof will open to vent position. I have done that a couple of times at home with fob in my pocket while crawling under my house to fix stuff.
I have also found the back door popped open which is easier to do unintentionally.
I do have the comfort access fob with a range of over 100' so that can easily happen while in the house at work or otherwise out of visual site of the car.
on
1 Post
Was the sunroof tilted or open? Tilted it would most likely be your pocket causing it. Open is another story.
https://www.northamericanmotoring.co...-pored-in.html
Pedro99
10-03-2015 10:56 AM
