Official WRC MINI launch
Old Apr 12, 2011 | 04:20 AM
love_mini's Avatar
love_mini
Some photos from the press launch event yesterday
Old Apr 12, 2011 | 04:26 AM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Old Apr 12, 2011 | 05:46 AM
CKeffer's Avatar
CKeffer
Too cool! Can't wait to see how they do.
Old Apr 12, 2011 | 12:39 PM
Mab01uk's Avatar
Mab01uk
Kris Meeke driving the new MINI WRC rally car at the launch at Plant Oxford
Old Apr 12, 2011 | 04:26 PM
DICKS GARAGE R53
WOW I would of loved to have been there!!!
One question though, Can he spin some doughnuts around a guy on a Segway?
Old Apr 12, 2011 | 04:36 PM
drewstermalloy's Avatar
drewstermalloy
Old Apr 13, 2011 | 07:42 PM
ol1bit's Avatar
ol1bit
Nice pictures!
Old Apr 13, 2011 | 07:46 PM
Torri91's Avatar
Torri91
That's so awesome. I keep seeing the WRC MINI launch info on Facebook as well.
Old Apr 14, 2011 | 09:35 AM
drewstermalloy
Did MINI ever release the specs on the WRC car? HP, TQ, etc...
I thought the Countrymans were the ugliest cars ever until I saw this thing!
Old Apr 14, 2011 | 12:15 PM
First07MINI's Avatar
First07MINI
MINI WRC Racer Demo
Check out this WRC MINI tearing it up!
http://www.youtube.com/watch?v=MhSzU7mE5cU
Old Apr 14, 2011 | 04:00 PM
love_mini's Avatar
love_mini
Dimensions:
Length: 4,110 mm Width: 1,820 mm
Height: adjustable Weight: 1,200 kg (FIA regulations)
Chassis:
MINI Countryman bodyshell with Prodrive roll cage exceeding FIA regulations
Aerodynamics:
WRC rear wing, WRC front bumper
Transmission:
Permanent four wheel drive Front axle: Plated limited slip Rear axle: Plated limited slip Gearbox: Xtrac 6-speed sequential
Suspension:
Öhlins Prodrive Macpherson strut, 3 way adjustable
Front brakes system:
Tarmac: AP Racing four-piston brake with 355mm in diameter Gravel: AP Racing four-piston brake with 300mm in diameter
Rear brake system:
Steering:
Hydraulic power assisted
Wheels:
ATS wheels Tarmac: 18” diameter Gravel: 15” diameter
Tyres:
Michelin (FIA regulations)
Engine:
Type: Four-cylinder inline turbo engine with direct fuel injection and air restrictor
Capacity: 1,599cc
Bore x stroke: 77 x 85.8mm
Compression: max. 12.5:1 (FIA regulations)
Max. output: approx. 310bhp
Max. torque: approx. 420Nm
Max. engine speed: 8,500 rpm (FIA regulations)
Cylinder block: Aluminium cylinder block construction with bed plate lower section
Crankshaft:
Steel crankshaft with reduced bearing diameters
Pistons:
Forged skirt pistons
Conrods:
High-performance steel
Cylinder head:
Aluminium DOHC (Double Over Head Camshaft) construction; four valves per cylinder
Valvetrain:
Two overhead chain-driven camshafts
Exhaust system:
Garret turbo charger, silencer, catalytic converter
Fuel system:
Single cylinder direct injection with 200 bar
Lubrication:
Dry sump lubrication with oil suction
Cooling:
Water/air cooler and oil/water heat exchanger
Flywheel:
Optimised motorsport flywheel
Old Apr 15, 2011 | 01:43 AM
cmt52663's Avatar
cmt52663
Krikey - 12.5:1 with a blower?
Madre de Dios!
Old May 9, 2011 | 02:14 PM
Agarwaen's Avatar
Agarwaen
This seemed like a good thread to add these pics to.
Just saw some photos from Top Gear of the Countryman in the Sardinia stage of the WRC.
That is going to be an uncomfortable landing
Apparently there is more than just the Prodrive team using MINIs. See the next few photos.
A Brazillian team
An Italian team
And then there is this Countryman
All pics courtesy of the Beeb.
Old Sep 2, 2011 | 06:27 PM
rescueme1060's Avatar
rescueme1060
So, what website do I need to visit in order to order an exact set of the wheels that this countryman uses? Does anyone know pricing and if they will work for an 02' MINI
Old Sep 2, 2011 | 09:25 PM
vIPkOhH's Avatar
vIPkOhH
Love the stance...that thing really looks like a 4 door hatchback to me
Old Sep 3, 2011 | 05:30 AM
PoppaDLo's Avatar
PoppaDLo
Love to see Ken Block take it our for a spin ... "literary a SPIN."
Old Sep 6, 2011 | 09:39 PM
Ken G.'s Avatar
Ken G.
Anyone else here been watching WRC on HD Theatre? They just showed Rally Germany where Team MINI's Daniel Sordo place third overall. HDT shows WRC with a several week "tape delay", but it's better than not seeing it.
Team MINI is also #10 in team points, which is pretty good given they've competed in only 3 out of 9 rallies.
I hope Kris Meek gets some better luck with his car, tho. He had to retire with electrical problems.
RESCUEME: I'm pretty sure the wheels used by WRC are specialty items and can't be used on production cars. I'm checking into that, however, since it's been a long time since I last looked into this.
Old Sep 7, 2011 | 08:07 AM
jaqattack02's Avatar
jaqattack02
You could start by looking here: http://www.ats-wheels.com/ats_wheels/index.php?option=com_content&view=article&id=50&It emid=58⟨=en
Old Sep 7, 2011 | 08:37 AM
Mini PoWA!'s Avatar
Mini PoWA!
I love how that WRC mini sounds!
Old Sep 8, 2011 | 07:20 AM
Ken G.'s Avatar
Ken G.
Yes, it has a distinct growl to it, just like a rally car should sound. Makes the Countryman a lot cooler, too. It probably will never make the TOP GEAR Cool Wall, but powersliding around a country lane at 60 mph doesn't hurt it's image.
kurosh
Aug 27, 2015 11:54 AM
kpl
Aug 11, 2015 04:52 AM
ludedude
Aug 10, 2015 07:16 PM
Aug 10, 2015 01:59 PM
