what is the best way to get a dealer decal sticker off my baby!
Old Mar 27, 2011 | 12:58 PM
MalloryJade's Avatar
MalloryJade
I didn't even think to tell the dealership to take it off before purchasing, my mistake! I first tried just peeling it off after i first bought my mini, and gave up with no luck. Does anyone know the absolute easiest and safest way to remove with no scratching or damaging the paint? Thanks a bunch !
-Mallory
Old Mar 27, 2011 | 01:49 PM
NMgokart's Avatar
NMgokart
Warm it up and peel it off. Much more difficult to do when they're cold. You may end up with a bit of glue residue..... WD40 takes it off easily.
Old Mar 27, 2011 | 01:59 PM
mini coop's Avatar
mini coop
Ask the dealer to do it?
sassiegyrl's Avatar
sassiegyrl
Hello, I have used a hand held hair dryer to remove decals before from racecars. That should help. That and WD-40.
Old Mar 27, 2011 | 05:52 PM
Vollgas's Avatar
Vollgas
Goo Gone
Old Mar 27, 2011 | 07:33 PM
ronnie948's Avatar
ronnie948
Hair Dryer
Heat the decal up with a hair dryer then carefully peel it off.
Old Mar 28, 2011 | 04:36 AM
Walt's Avatar
Walt
Sort of along the same lines as a hair dryer, I used a heat gun that we use here at work for shrink tubing. Just heated the dealer's decal for a few moments, and it just pealed right off.
Old Mar 28, 2011 | 06:03 AM
BoCRon's Avatar
BoCRon
You can also run a piece of fishing line or dental floss behind it after you've warmed it up a bit. Then clean up the residue with the WD40 like everyone suggested. You will need to put some sort of protectant back where the decal was since removing the decal will leave an unwaxed/unpolished spot.
I usually do a spot treatment of wax until I can get around to doing the entire car.
Annette
Old Mar 28, 2011 | 06:06 AM
buckland's Avatar
buckland
Be careful with the heat gun, they can get pretty hot.
Buck
Old Mar 28, 2011 | 10:52 AM
J_Westy's Avatar
J_Westy
Buck
yeah, for a novice, use a hair dryer.
I use
- warm with hair dryer
- pick/peel with a finger nail
- wipe up with 3M adhesive cleaner
http://www.amazon.com/General-Purpos...1334692&sr=8-5
Old Mar 28, 2011 | 11:28 AM
alwzopn's Avatar
alwzopn
how do you get floss behind a decal?
Old Mar 28, 2011 | 11:38 AM
BoCRon's Avatar
BoCRon
Once I've warmed it up a bit with a hair dryer I peel up one end, then I slide the floss under there. I use this method because I have the wimpiest fingernails and usually split a nail or something trying to peel off stuff.
Annette
USA-RET
Oct 10, 2015 09:52 PM
papawhiskey
Sep 14, 2015 05:47 PM
LowerKlass
Sep 10, 2015 05:59 PM
USA-RET
Sep 8, 2015 01:50 PM
Norton70
Sep 7, 2015 05:06 PM
