MCS (dual centered exhaust pipes) Trailer Hitch
Old May 17, 2007 | 08:44 AM
Ken Cooper's Avatar
Ken Cooper
I'm not sure I can see how a standard trailer hitch can be mounted to the Mini Cooper S having the dual centered exhaust pipes. Are there special hitches for this car? Does anyone have photos? Or what?
Old May 17, 2007 | 08:46 AM
mitchman's Avatar
mitchman
There's one that mounts behind the rear fog light. You just pop out the fog light and insert the hitch. Slick! (I don't have any info about it though, I just know that one exists)
Old May 17, 2007 | 09:08 AM
Drillslinger's Avatar
Drillslinger
And the MINI-FINI Sport Link now has black caps that help the ports blend in better
Old May 17, 2007 | 09:18 AM
CTDAVID's Avatar
CTDAVID
Mini Fini black caps
Why would you want to cover those beautiful tubes? I WANT the people behind me to believe I can lay down an oil-slick or shoot flames or scatter tacks!
Old May 17, 2007 | 11:19 AM
JCWGrover's Avatar
JCWGrover
https://www.northamericanmotoring.co...minidomore.com
Old May 17, 2007 | 11:21 AM
davavd's Avatar
davavd
http://www.miniaturetrailer.com/
Old May 17, 2007 | 11:32 AM
JIMINNI's Avatar
JIMINNI
Very cool . Thanks for the link.
Old May 17, 2007 | 11:35 AM
BlimeyCabrio's Avatar
BlimeyCabrio
... and the MiniDoMore / MiniatureTrailers hitch (same hitch and same company) is a relatively easy install and works great. I have it and have no issues.
There are some compromises / tradeoffs associated with both this hitch and the MiniFini...
* MiniDoMore Pros: accepts "standard", relatively low cost 1-1/4" attachments (hitches, cargo carriers, bike racks, etc.). These add-ons tend to be less expensive than the MiniFini attachments. Invisible when no attachments are on the car (hidden by the rear fog light or grille)
* MiniDoMore Cons: you have to get on the ground, and reach under the car, around a (potentially hot) exhaust, and probably bend back the heat shield a bit to install attachments, because where the pin installs is hidden behind the bumper. Attachments must have a fairly long 1-1/4" mount, or they may not recess far enough into the bumper and thus may be un-usable (not every 1-1/4" bike rack will work, for example).
* MiniFini Pros: no crawling on the ground or reaching into uncomfortable places to mount attachments. Some people think the twin pipes look cool when nothing is attached.
* MiniFini Cons: Attachments are proprietary and expensive. I think the tongue weight rating is a bit lower than the MiniDoMore. You always have the "oil slick/machine gun" tips protruding, like it or not. Attachments don't look as clean (IMHO) because of how they mount.
Hope this helps.
Old May 17, 2007 | 12:16 PM
bzn by's Avatar
bzn by
We have the mini do more hitch and love it, used it a few times and as posted above, installation was relatively simple
Old May 17, 2007 | 01:04 PM
Ken Cooper's Avatar
Ken Cooper
Well .. I liked the dual rear fog lights on the R56S .. Until now.
https://www.northamericanmotoring.co...0&ppuser=29789
But I suppose you could cut through that 4" high plastic mesh looking material to get to the frame. It looks like there's a 1/4" x 2" L bracket back behind there.
Old May 17, 2007 | 03:04 PM
200-OK's Avatar
200-OK
I believe Brent (aka Miniaturetrailers) has something in the works for the R56S. You might want to PM him and ask...
Old May 18, 2007 | 07:54 PM
BoCRon's Avatar
BoCRon
Here's mine.
Annette
Old May 18, 2007 | 08:26 PM
BlimeyCabrio
Ooooooo....
Annette - I dig your tail.... lights... taillights.
Old May 23, 2007 | 04:40 PM
Free Spirit's Avatar
Free Spirit
Coordinator :: Arkansas MINI Owners Klub (AMOK)
I'm getting ready to install the MINI Do More this weekend, Memorial wknd, any tips from those who have installed it?
Old May 23, 2007 | 08:40 PM
Ken Cooper's Avatar
Ken Cooper
Have you thought of documenting your work with photos?
I've ordered a trailer (Little Guy 4 wide platform teardrop - 770 lbs.) and it's ready for me to drive up to Colorado to pick it up (drove up today to see it, check it out, and ordered it - 800 miles round trip). Now all I need is the hitch (I'll order it tomorrow - tired - long drive)
I've tried to read and understand the instructions. I'm wondering if I'm up to this job. Hate to pay someone else to do it. So, back to the idea of documenting your work with photos. It might be helpful to some of the rest of us (moi). If you don't, I will (if I can get up the nerve to tear that whole bumper assembly apart).
I'm tired .. I'm rambling .. I'll write more tomorrow.
Old May 24, 2007 | 02:47 AM
200-OK's Avatar
200-OK
I thought the installation instructions were spot-on... Just follow them and you will be fine. I did find it helpful to have a second set of hands when it came time to mount the new hitch to the frame, but it is possible to do it by yourself.
The only point I remember being concerned for a minute or two was the point where I unplugged the wires from the bumper cover. Trying to do that with one hand while holding the bumper cover with the other was a bit tricky; but they do come off pretty easy once you figure out how they are clipped in...
Just be real careful once you pull the bumper cover off; find a clean, soft spot to put it on so you don't scratch the paint on the outside of it.
The entire install probably took me 3 hours, but that was way too long. I was moving very slowly; almost methodically. It was also the first mod I did that require me to raise my car and remove the wheels, so I did a bunch of exploring.
Sorry I didn't take pics; in hindsight that would have been a good idea. But really, they wouldn't have been any better than the installation instructions...
Good luck, feel free to PM with questions...
-Ed
Old May 24, 2007 | 04:23 AM
BlimeyCabrio
Really is an easy install. If you have a couple of properly sized cardboard boxes sitting below the bumper while removing it, they are a handy place to gently lay/lean it while unplugging the wires.
Also, I found that if you have a stubby phillips screwdriver, you can do it without jacking or removing rear wheels. You need the stubby to reach the screwclip inside the rear wheel well.
Otherwise just follow the instructions.
Old May 24, 2007 | 05:30 AM
Free Spirit
I plan on taking pics and notes. So I'll post once I'm done. I'm doing it on a weekend so my husband can be standing by. So if I can do this, anyone can!! We have a big trade show (custom knives) coming up in Atlanta (Blade Magazine is hosting June 8-10) so he's really busy with that. Which is one reason I'm doing this. That and it's my MINI I want to be able to do it. (I'm not that possessive, honest!) We are planning on going over to the Dragon after our knife show and he has a Ducati we are trailering.
If you're in the Atlanta area lmk, I'd love to come meet you and your MINI. The Friday we are there I plan on taking my daughter around to some of the historic sights. I'm hoping we'll get there early enough Thursday so my husband can go with us to the Cyclorama and Oakland Cemetery.
Old May 24, 2007 | 05:50 PM
Jdewey's Avatar
Jdewey
little guy tear drop
deleted.
J D
Old May 24, 2007 | 06:07 PM
Ken Cooper's Avatar
Ken Cooper
Thanks! I feel more confident now. Just put in my order today. As soon as it arrives I'll install it then head up to Woodland Park, Colorado to pick up my new Little Guy Tear Drop Camping Trailer then head out to California on vacation.
Old May 25, 2007 | 06:39 AM
DixonL2's Avatar
DixonL2
Ken: The MDM hitch install is a breeze, I've only done a few but can probably do it in an hour now. The hardest part has been noted - removing the bulbs, a simple twist and pull complicated by holding the bumper cap up - the bumper cap is light, but large, and you don't want to scratch it - and the first time you remove it you're asking "have I gotten all the fasteners off?".
The only complication on one install (a cabrio) was removing the cabrio tailgate hinge covers and tailgate itself - which ended up not being a big deal at all.
If you were near Pittsburgh I'd offer to install it for you, I'm actually doing a hitch change-out this weekend (putting a non-foglight hitch in place of a foglight hitch).
That's one thing to be aware of - Brent (minidomore) has a couple of models of hitch, the 2002-2004 (for models with rear fog or backup light) is more recessed behind the bumper and requires a somewhat longer hitch drawbar (some 7" from hole to bumper cap surface). The 2005-6 hitch (the "1003") is closer to the surface of the bumper cap since there doesn't need to be room for a rear fog or backup light. The drawback of the earlier hitch model is that some bike racks won't fit due to the distance - the bike rack's "drawbar" length just isn't long enough.
Double check the tightness of your bumper bolts too - 4 on a side - on one cabrio we found improperly torqued bolts holding the bumper on - several were just a little more than hand tight! I think MDM gives the torque specs of ~50 ft-lb (not as tight as lugnuts, I remember, but I do NOT remember the exact number). If there's not a torque spec, it's "really tight" on a 6" ratchet handle, and "quite tight" on an 8".
Good luck, let us know how it goes!
PS: The problem with my hitch is that now I'm looking at the dual exhaust mod - even though installing the drawbar isn't that bad, it'd certainly be easier with the side-mounted duallies... the mod bug is ALWAYS biting...
Old May 25, 2007 | 07:07 PM
Ken Cooper's Avatar
Ken Cooper
Dixon .. Thanks! It looks like I'll be receiving my UPS parts delivery a week from today. And thanks especially for the cautionary suggestions.
Old May 29, 2007 | 08:58 AM
DixonL2's Avatar
DixonL2
OK, My wife and I re-installed the MDM hitch 2 nights ago - in 50 minutes! That included the obligatory "No, I need a Philips, not a straight blade" comments, as well as set-up and take-down. Add 5 minutes for washing hands and opening the traditional post-fix beverage. Budget about twice that for your first install though.
We replaced a reverse/foglight model (1002) with a non foglight ('05-06, or 1003) because the 1003 puts the drawbar hole closer to the bumper cap.
I thought of a couple other items:
1) The philips-screwdriver plastic clips (there are about 4 of 'em) get unscrewed BUT you have to hold the outer perimeter of the clip to unscrew the inner "plunger". Sometimes they strip, in which case wedging a straight blade screwdriver between the "plunger" inner part and the outer part can help the plastic threads to engage. Reinstallation takes no screwing around, just wiggle the prongs into the hole and push the center part so it's flush. (easier to do than to describe).
2) You'd need a VERY short philips screwdriver to reach the inner fender clips without jacking, but a 90 degree will do it. May need small fingers too. It can be done but jacking is easier for me and brings the hitch up a few inches (better for bad backs!).
3) You can most likely pry the rearmost part of the fender trim away with your fingers, it just pops out. Gentle pulling, rotating your fingertip under the back edge part of the flare should do it. Sometimes the rearmost clips break and MDM thoughtfully includes extras. Occasionally 1-2 white clips (further forward on the flare) come disengaged, just be careful and you can re-engage them in the flare then onto the body. You'll do fine. Don't pry with a metal object!
4) You'll need to ziptie the short wiring loom back onto the car - it's easy. I decided to ziptie it onto the hitch since the groove in the top of the fender may collect moisture and wiring doesn't usually like that. MDM includes zipties; I added a couple because I had 'em. Just route the wiring so it's not pinched or rubbing on sharp edges.
That's about it, not a hard install.
Oh - and there's no room behind the bumper for a rocket launcher, rear-firing anti-tailgating spray reservoir, oil slick or smoke generating device. Darn.
Old May 30, 2007 | 06:26 PM
Free Spirit
I put on my MINI Do More trailer hitch for a S convertible this past weekend. MINI Do More, your instructions are great! Easy, step by step, very well explained. I did most of it. My husband held the bumper while I unplugged the lights and sensors, he helped put on the hitch. The heat shield did have to be pushed down a little for the hitch to line up correctly (make sure the heat shield does not sit on your exhaust, it makes a funny noise that is not desirable.) We also installed MINI Do More's wiring harness, more detailed than the hitch, but they did a great job with instructions. I pulled everything apart, most of the plastic on the inside of the trunk has to come out, he did the actual splicing. It was easy though because they provided wire splicing clips where the two wires are put in this clip and when you shut it it cuts into both of the wires. A chart was given to know which wire goes with which wire.
I did take pics which I'll post later, I'm at work now.
5 minutes after the hitch was on it started raining! That was close. Thanks to the Man upstairs it waited til I was done! It poured, one of those summer showers. It rains hard for a few than acts like it never did anything.
Jan 4, 2019 12:51 PM
theateist
Aug 22, 2015 06:58 AM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
