FSP/DSP (Street Prepared) Have modded Cooper or Cooper S and want to run R-compound tires? Join the discussion here and find out what rules allow in this sticky-tired class!
Lifting inside rear wheel
Old 09-17-2007, 05:54 AM
terry glazar's Avatar
terry glazar
terry glazar is offline
Yesterday I attended an autoX and was told by one of the other Mini guys that my inside rear tire was lifting off the ground about 4 inches on the left sweeper. My question is this normal for the Mini?
Also my front tires are wearing on the outside edge, I have 2.3 degrees of negitive camber in the front. I have tried anything from 40 to 50 lbs of front pressure with not much change in edge wear. This may be normal and I am just looking for an opinion.
My car is a 2006 MCS JCW with Kumho V710, H rear bar on middle setting, stock front bar, M7 coilovers, camber plates. Alignment is 1/8 toe out F, 0 R. 2.3 neg. camber F, 1.3 R.
Thanks for any light you can shed on these two.
Terry
Old 09-17-2007, 06:00 AM
Loony2N
Loony2N is offline
Mine does it when it is going to mark a hydrant or bush
Old 09-17-2007, 03:58 PM
mzman
mzman is offline
This is really common. Ours is on three wheels on most corners. Even the 245/35/18 wheels come off the ground (see first picture). Last month, My wife had it up on 2 wheels at the ProSolo and the SCCA officials were getting nervous . The second photo is Mitch Lewis on 3 wheels.
Attached Thumbnails Lifting inside rear wheel-dsc_0064.jpg   Lifting inside rear wheel-dsc_0099.jpg
Old 09-17-2007, 09:33 PM
Rsstopper's Avatar
Rsstopper
Rsstopper is offline
Coordinator :: RSR Motorsports Forum
Your pictures indicate that the front spring rate is too low. You need to either increase your spring rate or increase your roll bar. . . springs first . . . bar second. Tire size has very little to do with this.
The spring should support the weight and the 'load' that you are placing upon it. The bar should assist with weight transfer. The shocks should dampen the spring rate.
Lifting your rear tire is a nice 'photo op' but not good for handling. If your wife's car is lifting two wheels off the ground, the officials should be worried! . . . not about an incident but about lousy course times! She can go much faster if you fix this.
Old 09-18-2007, 06:18 PM
mzman
mzman is offline
You're totally right. Since those pictures were taken, we've been trying many different spring rates and I think we have it now. I think I'm on my 4th set of springs :( but the car is getting pretty fast. The springs that came with the Leda coilovers were waaay too soft. I'm running on hypercoils now and it handles way better. Hopefully it will show in our times at Nationals. I feel sorry for the guys running GS with stock springs.
-- Allan
Old 04-17-2008, 10:54 AM
funracer
funracer is offline
We have a 2004 JCW w coilovers. Inside rear wheel lift was common last year. Added the Texas Speedwerks underbody brace this year and it has nearly eliminated rear wheel lift. Oddly, I could not find it on the company website. I bought mine from Autoxcross Cooper:
http://www.autoxcooper.com/tsw_suspension.html
Good luck.
Old 04-17-2008, 12:04 PM
Bhatch's Avatar
Bhatch
Bhatch is offline
The rear lifts due to too muchload transfer and not enough drop on the rear.
In either case that tire has no load on it and an effort should be made of minimize it.
You can see here how a stiff suspension can still give you lots of 3 wheeling, but because i have very little droop, lots of front spring and sticky tires. These were 600ft.lbs springs all around with SpSS3's
That DSP mini needs more spring.
Old 03-04-2009, 02:17 PM
MotorMouth
MotorMouth is offline
The pic in my sig was taken with stock sports suspension. After I installed the cross coilovers I still get 3-legged but not as often or with as much height.
Old 03-04-2009, 04:28 PM
ChipG's Avatar
ChipG
ChipG is offline
With a little more traction I'll be lifting the wheel
Here's neOlain with a little 3 wheel motion
02-07-2019 05:23 PM
wkp1219
11-13-2015 07:52 AM
I_drive_slow
08-18-2015 10:47 AM
Powershift
08-16-2015 05:14 PM
W0TM8
08-16-2015 12:32 AM
Quick Reply: Lifting inside rear wheel
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
