Limp mode at 2500 rpm
Hi all, I'm a newbie, so if this has been answered elsewhere please forgive and redirect me. The issue:
My wife's R60 all4 S manual trans, throws a CEL/ enters limp home mode (yellow, not flashing, half engine icon shows up on dash) whenever these very specific instances occur: going up hill, part (about 75%) throttle, at 2500rpm. It is very regular. It also resets fine next time the ignition is turned off and it is turned on and driven. She has taken to driving "one gear lower" to avoid it.
85000 miles on car. It has a new(er) hp fuel pump, and ignition coils (both replaced in the mid 40k range) Sparks done as per maint plan. MAF sensor also replaced a while back. Issue has lasted through many many tanks of many brands of fuel. Car seems otherwise OK.
I have not read to see if there are any stored codes (I don't have the special BMW scan tools, but do have a regular OBD-II / CAN BUS scanner.
any help would be greatly appreciated.
Update
just (tried to) read the fault codes on my wife's mini. As i suspected, nothing stored or at least nothing I can pick up (using BAFX OBD II Bluetooth dongle and Torque app.)
To be clear, CEL is currently off (as usual...as per original post the code clears after restart / normal run)
I also should have added that the car is a 2011 in case that matters.
has anyone else ever heard of this issue? The things that make it so odd to me are that it happens mid load, mid rpm, warmed up, and it is so repeatable. Very odd bunch of symptoms in my (limited) experience. Also there is no noticible sound / hesitation / anything when it happens...just the CEL and accompanying chime.
again, any input is welcome.
All of the following have been replaced...
Parts that have been replaced:
Sensor P/N 13 62 75 99 907
Sensor P/N 13 62 75 99 906
Sensor P/N 11 65 75 99 547
and the high pressure fuel pump PN 13517592429
... but the issue persists.
