Side scuttle removal F54
So i answering my own question. To remove side scuttle for mini clubman F 54 necessary open hood and unscrew 3 screw from cover over the fender ( look to manual how to change side marker bulbs) when you remove cover you will see inside spring connector (on front of side marker) push it from inside out and remove side scuttle forvard and out. After removing disconnect light and slide forvard insert if you wish to change it. Install new insert push it back to lock in place and assemble everything back
