F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
Slow Clock ????
Old Dec 21, 2015 | 03:38 PM
Baby Six's Avatar
Baby Six
Slow Clock ????
What's with the slow clock,
please don't tell me Mini can make an accurate clock?
Old Dec 21, 2015 | 09:41 PM
Fly'n Brick's Avatar
Fly'n Brick
Again with the unanswerable question. Some basic information about your MINI and are there other electrical anomalies going on would be of great help.
As a point of reference, I set the clock back in '08 and didn't have to adjust it 'till just a couple years ago when the battery was replaced and it is still solid right on.
Old Dec 22, 2015 | 09:14 AM
Baby Six's Avatar
Baby Six
It a 2016 Mini, New Battery, Maybe it has something to do with putting a battery tender charger on it once in a while.
I'll reset the clock and check 2 weeks later with no charger attached.
Old Dec 22, 2015 | 12:27 PM
anotherminiinthegarage's Avatar
MINI is not the clock maker. If you have a bad one talk to your dealer
Old Dec 22, 2015 | 12:42 PM
Yea, the clock issue was back in the 05-06' with the cluster, have not heard of issues with the F56. How much time is it losing ?
Old Dec 22, 2015 | 09:36 PM
pppdxx's Avatar
pppdxx
My 2016 F55 loses about five minutes every week... That is until I coded the car to set its time via GPS. Now the clock is always accurate. Like smartphone accurate.
Old Dec 23, 2015 | 02:16 PM
hammerhands's Avatar
hammerhands
I think mine sets itself to my iPod?
Old Dec 24, 2015 | 10:08 AM
Baby Six's Avatar
Baby Six
Coded car ? How do you do that ?
My clock is about 5 minutes per week slow.
Old Dec 24, 2015 | 10:58 AM
Blues Trucker's Avatar
Blues Trucker
Yep, mine losses about 5 minutes per week too.
Old Feb 27, 2016 | 07:43 PM
thays_91's Avatar
thays_91
Not to raise an old thread but my 2016 F56 S is also loosing 3-5 min each week.
Old Feb 28, 2016 | 02:04 PM
siriuszero's Avatar
siriuszero
Those who are losing time, do you have Connected XL? The reason I ask is that I've been told there is a bulletin out for a known issue where the clocks are losing time but it only calls out MINIs with the XL headunit. The March software coming out will supposedly fix it and there is a temporary workaround in place now.
I'll see if I can find the bulletin number
EDIT: It's SI M62 05 15. Might be worth asking a service advisor
Last edited by siriuszero; Feb 28, 2016 at 02:05 PM. Reason: added bulletin number
Old Mar 2, 2016 | 06:34 PM
Baby Six's Avatar
Baby Six
Maybe it me, I've checked the clock a few times since I started this post, clock is on time, not sure why. Maybe it linked it's self to the moon ?
Old Mar 3, 2016 | 10:06 AM
BowlInJar's Avatar
BowlInJar
Thanks siriuszero! I have a 3 month old 2016 Justa with Connected XL and it looses about 4 minutes each week. I've been meaning to give the dealer a call, but haven't gotten around to it. Having this information will be helpful!
Old May 3, 2016 | 06:34 PM
gooseunc's Avatar
gooseunc
I've got the same problem...how do you code the Mini to sync with GPS?
Old May 5, 2016 | 12:48 PM
siriuszero's Avatar
siriuszero
Get setup with ESYS first for coding - there are numerous threads here and on Bimmerfest to get you started.
Once you got your setup running, there are 3 parameters you have to change. Keep in mind, you need navigation for this to work:
Two in HU_NBT - set both to "aktiv":
CLOCK_CHANGE_AUTOMATIC
SETTINGS_TIME_AUTOMATIC
One in KOMBI - set to "aktiv":
GPS_UHR
Once coded, go into iDrive, go to Settings, Time/Date and you'll see the option to set automatic time on.
Old Jul 21, 2016 | 04:11 PM
Camyman's Avatar
Camyman
There is a bulletin out now for MINI cars WITH navigation but WITHOUT heads up display. There is an internal software error for the KOMBI that gets rectified. Make sure you tell your dealer to read the bulletin and make sure they are using ITSA/P 3.59 or higher. Older versions will not code out this issue.
Old Sep 3, 2016 | 01:48 PM
Danscrazyhair's Avatar
Danscrazyhair
I've got a slow clock too. Loses about 10 minutes per week. Do I need to have my car coded, or is there a software update for this now?
Old Sep 3, 2016 | 01:55 PM
BowlInJar's Avatar
BowlInJar
I had the software update applied to my 2016 (Nov 15 build date) about a month ago and the clock works as expected now.
Old Sep 3, 2016 | 02:04 PM
Danscrazyhair
Great! Going in next week for an oil change. I'll make sure to get this done.
Old Sep 6, 2016 | 01:51 PM
Thanks for the update with the software working now.
Mega Babies
Tires, Wheels, & Brakes
15
Jul 13, 2018 03:49 AM
I_drive_slow
Jun 11, 2016 07:42 PM
Niccolo_Machiavelli
Navigation/Audio
Nov 8, 2015 03:43 PM
