No rear braking?
I have a 2009 JCW. Just purchased. My braking was marginal. I checked the frond pads and rotors. All Were good. Went to the rears and found a mess. Who does things like this. They had a standard mini 10" rotor with the Brembo caliper.
Half the pads were worn down so far that the portion of the pad not on the rotor were actually touching each other preventing the pads from grabbing the rotor. Just thought I would throw this out their for comments. I have pictures but I'm having a problem loading them. |
Whiskey Tango Foxtrot.
Would be interesting to hear what the seller has to say. |
Looks like they replaced the rotors with regular S rotors, and not JCW rotors.
WTF indeed! |
funky groove in the rotor too.. not oem is it?
That's not a groove, its the slotting from ATE rotors. The poster is correct above, that the rotors are the wrong size for the JCW rear brakes. The pads are the same size as on the S, but the rotor is larger. https://www.tirerack.com/brakes/brand.jsp?brand=ATE |
Originally Posted by NJ Mini
(Post 4419328)
That's not a groove, its the slotting from ATE rotors. The poster is correct above, that the rotors are the wrong size for the JCW rear brakes. The pads are the same size as on the S, but the rotor is larger. https://www.tirerack.com/brakes/brand.jsp?brand=ATE do they exist in the states? they worked really well on my r53 in combo with the ate hpbk up front |
