Does a 2009 JCW Need a Oil Catch Can?
I have been reading up on some of the concerns, issues and problems people have had with their MINI's. One has been the concern with oil and water vapors through the PCV system causing carbon deposits on the intake valves and oil and water in the inter-cooler. With a direct injected motor there is no detergent additives from the fuel washing the back of the intake valves and oil and water in the inter-cooler reduces it's effectiveness. Is this a concern on the JCW's motor as well. It is a simple mod to do and I see that there already is a effective mod available for the Cooper S's. Does this mod (BSH Catch Can) work on the JCW equipped cars as well?
I am aware of the effectiveness of using a catch can as they are common mod on the Corvettes as well. The LS series of engines have a less than effective PCV system. Many of us just use breathers and delete the PCV altogether. I didn't go that route as my wife and I don't like the smell breathers allow to enter the car. |
An oil catch can isn't necessary, but a good addition. And it will work on your JCW. We've found the BSH can to be the best avail for the R56 cause the design of the baffle inside the can, and machined fittings to attach it to the valve cover.
is this an easy install? are there any install instructions up on the forum or web?
I have a 2009 factory JCW and before I installed the BSH catch can a slight oil film could be seen on the inside of the turbo inlet hose but after I installed the BSH can ( at about 1000 miles) it remains dry. The BSH can is sized right to fit the Mini and was easy to install. The can on my JCW does not collect nearly as much as some of the others I have seen post here but it does collect moisture and oil enough to keep my turbo inlet dry and keep that stuff from flowing into the intake. BTW I also have the line where the BSH boost tap goes pluged so all the flow goes through the BSH catch can.
The install is very easy.
I asked the shop forman at my local MINI dealer about oil catch cans and he said that they haven't caused any problems on cars with them that have come through the shop and he's seen a few! Dave |
so the BSH can is the best choice available then?
I don't know how well the Draft42 catch cans fit the Mini but they seem to have a very good baffle system.
heres some photos of what is caught in a catch can
3 Attachment(s)
WOW:eek2:
From the looks of the last set of pictures, this will definately be the first addition to my 2012 MCS that will be arriving within a couple of weeks! :eek: That looks pretty nasty. My concern is having any warranty issues, do you think I would be better off asking the service manager at my MINI dealer, or just removing it whenever it has to go in for service?
Get the BSH can from Way Motor Works.
I put one on after I got my 2011 JCW. It's an easy install. |
How do you empty the occ and how often do you have to empty it
there is a drain screw, have'nt had the car long enough to get a baseline on dump frequency's( looks to be often)
Originally Posted by lvegas
(Post 3411215)
I got a battery filler from Harbor Freight.
http://www.harborfreight.com/battery-filler-96571.html It reaches to the bottom of the BSH oil catch can through the dipstick hole and does a good job of sucking the slop out. I wrote OIL on it, so that I don't accidentally use it for something else. I check the level whenever I check the oil, about every time I put gas in the car. It fills faster when the weather is cold. Dave |
I'm wondering what happens when it freezes up:eek:
50cc's in two weeks! maybe a couple of hundred miles ,:eek2:I'm logging milage/sludge data now.
(Post 3411215)
I hate to be the stupid newbie here, but can somebody please explain exactly what an oil catch can does? And, at the risk of getting flamed, why go with this BSH can over one of those nice looking anodized ones or the cool looking M7 version?
It has been asked here many times:nod:
Originally Posted by anitan1
(Post 3421167)
Care to point me in the right direction?
Originally Posted by JPMM
(Post 3421175)
The BSH oil catch can has a baffle in it that makes it more efficient, it also has a dipstick so that you can check the level of the slop that it accumulates. That, and the dual boost port, that only pertains to 2010/2007 cars makes it the best choice.
Dave |
(Post 3421167)
Since the turbo'ed "S"-model engines are direct injected, there's no fuel washdown on the backside of the valves in the cylinder head. As a result, the valves can have significant carbon build-up due to the oil vapor being baked on the valve. Many have documented that adding a catch has reduced the amount of carbon coking on the valves. - Erik |
(Post 3421167)
85cc's at about 300 miles( 30 mile round trips, a few days of rain, temps from 20 to 50 degrees, with a fresh MINI oil,oil change)
(Post 3411346)
New NM Engineering Catch Can
Anyone used this one? Way Motor now sells this as well. I'm a big NM Eng fan and their system has the typical Good Looks of NM stuff.
I had a BSH catch can installed on my Clubbie about 9,000 miles ago - I check it when I check the oil but I have never seen anything on the dipstick. Maybe I should pull the can to see if there is anything in the bottom? Since most people have to empty theirs periodically, should I be concerned that I don't see anything on the stick?
Thanks.
(Post 3426065)
Water is hard to read on the dipstick as it doesn't cling like oil.
I got one of these at Harbor Freight. http://www.harborfreight.com/battery-filler-96571.html It fits right down the dipstick hole and I can quickly suck the oil and water right out! Dave |
