F60 Winter set up....
Winter set up....
Ok I'm sure I'm missing this but I've looked and can't seem to find the answer. Granted I got in at 3:30am and I'm still a bit groggy.
Looking for a good winter wheel/tire setup. What are the wheel specs for a 2017 CM All4S? I found the bolt pattern but can't seem to find the correct offset. Tirerack shows the old CM so I'm not sure I believe what they're telling me.
Anyone have any other options besides Tirerack?
Thanks y'all.
Dave
Thanks y'all.
Dave
Hey, I'm also looking for your insights to winter wheels/tires... Planning on pulling the trigger on a JCW F60 with 19'' and summer tires. That won't work here in Snowy Montreal...
Thinking 18 with 225/50/18 would work... wheel specs? TPMS? (need bigger to clear Brembos)
What have all you done?
thanks
E
thanks
E
thanks
E
thanks
E
I was going to do the same thing too but ended up keeping the stock 18" rims, swapped the rubbers to Blizzak WS80s, sold all seasons. I will pickup 19/20" aftermarket rims and tire in the spring. This ends up cheaper than upgrading with mini and buying a separate set of 18" rims for winter, also more options for the summer rims too.
I am in the market too.
I have an '18 with 225/50/18. The issue is not the tires, but the wheels.
The overall rolling diameter needs to be 26" and the offset is very specific due to the brembo brakes.
I do not want to swap tires 2X/ year on the stock wheels - but will if II have to.
If anyone has found a tire/wheel combo, please post up!
https://www.etkbmw.com/bmw/EN/parts/...ed/36110048011
at $180CAD for these motegi it’s much more palatable for rough Canadian winters
https://www.northamericanmotoring.co...gi-wheels.html
not at €500 each!
Klasse Act
Tires, Wheels, & Brakes
12-09-2009 04:17 PM
jlivingood
09-25-2006 01:18 PM
