F60 :: Countryman Talk (2016-2023) F60 Countryman discussion
F60 Carplay finally!
  #76
Old 10-17-2018, 04:29 AM
DarkMiniCooperS's Avatar
DarkMiniCooperS
DarkMiniCooperS is offline
Originally Posted by MKDrCr
Hi all,
I purchased the code update from bimmercarplay. Install was easy and everything had been working well. With the new updates to ios12 and to the waze app was really looking forward to using waze via CarPlay. It won’t work though! An error that waze can’t connect to GPS shows at the top of the screen and the app doesn’t function correctly. On reddit, I’ve read that other car models, specifically the Nissan Rogue, have had an issue similar to this, but I’ve seen no complaints about a Mini.
I have a 2017 Countryman S All4. I haven’t reached out to waze yet since the 2017 Countryman is not technically a “supported” CarPlay vehicle; I was curious if any one has had any problems?
I have a 2017 Countryman with retrofitted CarPlay. Waze works fine here.
  #77
Old 10-19-2018, 01:52 PM
MKDrCr's Avatar
MKDrCr
MKDrCr is offline
Originally Posted by cddakin
Exact same issue here - same car. Would be interested to see if anyone with a 2018/2019 has tried it.
No problems with Google Maps, so hoping it is an app specific issue that may be fixed.
Same thing here, google maps works fine. It looks like there is a Waze beta out there that fixes it for the Rogue, hope it works for us too!
  #78
Old 10-21-2018, 06:58 AM
ND40oz's Avatar
ND40oz
ND40oz is offline
I can't get CarPly working on the '19. It looks like they're doing the same thing BMW did and relying on Mini Connected to download/enable the CarPlay app instead of having it already installed/enabled. Same problem I have with my '18 X3.
  #79
Old 10-22-2018, 06:57 AM
carimer's Avatar
carimer
carimer is offline
I have 2018 Countryman S E and Carplay continues to work well with Waze. I have most-recent version of Waze, and iOS updated to most recent version. No issue seen here.
Separate question -- I have the built-in armrest wireless phone charger and I'm noticing that basically whenever I put my phone in the charger, it stops charing 10-15 minutes after I put it in. It's basically not-useable and I now have a charging cable from the USB port plugged in & drop the phone in one of the cup holders. Anyone else seen this problem with the armrest wireless charger?
  #80
Old 10-30-2018, 02:48 AM
iamgrego's Avatar
iamgrego
iamgrego is offline
Kontak - are you from Greece? I'm trying to make carplay work on a 2017 countryman have you found a solution? Thanks
  #81
Old 10-31-2018, 05:26 AM
Budgett's Avatar
Budgett
Budgett is offline
Hello, I'm from Spain, I have a mini countryman from November 2017, I want to have the carplay, I have the 6.5 inch navigator, can I do the coding to have carplay? I have the following options installed in my mini:
06fp radio visual boost
06nm mini connected
06um mini navigation system
I've seen mini with that equipment and original carplay, which makes me think that if I can activate it, without having the professional browser
Thank you .
  #82
Old 11-01-2018, 03:19 AM
MinisINCornwall's Avatar
MinisINCornwall
MinisINCornwall is offline
06nm mini connected
Thank you .
It depends if your Mini is running iDrive 4 or iDrive 5 for the navigation system. My guess is you are running iDrive 4. Send your VIN to one of the CarPlay suppliers list in this post and ask them.
Budgett (11-01-2018)
  #83
Old 11-01-2018, 03:50 AM
Budgett's Avatar
Budgett
Budgett is offline
Thank you very much for the reply ! If you have 4, can you update to 5?
  #84
Old 11-01-2018, 05:37 AM
Budgett's Avatar
Budgett
Budgett is offline
it seems that I have found some more information, by the version of my maps that is the road map europe way, I have the new 6.5 navigator known as HU_ENTRYNAV2 or also known as ENTRYNAV EVO, it carries new animations such as when you activate the mode sport, then maybe I can activate carplay?
  #85
Old 11-01-2018, 07:10 AM
MinisINCornwall
Does your screen look similar to this. If it does you are running iDrive4 and can't install CarPlay.
The following 3 users liked this post by MinisINCornwall:
bluonyx (12-06-2018), Budgett (11-01-2018), Firewire (03-24-2021)
  #86
Old 11-01-2018, 10:41 AM
Budgett's Avatar
Budgett
Budgett is offline
This is my unit, is diferent, Maybe is id5, is possible carplay?
  #87
Old 11-01-2018, 11:22 AM
MinisINCornwall
In the UK if you have this interface then you get CarPlay as standard (both 6.5 and 8 inch screens) - so my guess is you can have it coded/FSC installed.
  #88
Old 11-01-2018, 11:31 AM
Budgett's Avatar
Budgett
Budgett is offline
Thank you very much for the answer, I consulted two, one tells me that I can not, the other has asked me the last seven numbers of the vin and I am waiting for news, although everyone says that if you do not have the professional navigator, it is unfeasible
  #89
Old 11-02-2018, 07:01 AM
Budgett's Avatar
Budgett
Budgett is offline
more news, no bmwcoder can do it, so it seems, the team supports it technically, but they have changed some of the bmw security system for the creation of fsc and can not activate it, and I can not buy the service in bmw, because only can the cars from March 2018 on, mine is that it has the same hardware of March 2018, but without being able to use these services since my car is November 2017, I guess we will have to wait until they find the way to crack the system.
  #90
Old 07-10-2019, 01:55 AM
stingray69's Avatar
stingray69
stingray69 is offline
I have the same problem, Countryman F60 12/2017 with 6,5 touch screen and navi. How is it possible that there is not a solution...
what are the hardware differences between a car produced before March 2018 and a car after March 2018 (photo attached)? Only the head unit?
  #91
Old 09-04-2019, 09:13 AM
Jesse Goldman's Avatar
Jesse Goldman
Jesse Goldman is offline
android Auto
Hey guys,
Just bought a 2016 mini countryman s. I want to install android auto or android mirroring in my car. I know i can buy a new head unit but would rather not blow $600-$800. Is there a file i can download to install this on my mini?
  #92
Old 09-04-2019, 09:23 AM
GnFnRnBacon's Avatar
GnFnRnBacon
GnFnRnBacon is offline
Originally Posted by Jesse Goldman
Hey guys,
The 2016 is an R60, not F60 (despite this F60 forum's title saying 2016+) Probably better asked in the R60 forum.
This is also a CarPlay thread. Probably better asked in an Android-related thread.
Enjoy your Countryman!
  #93
Old 10-27-2019, 06:19 PM
maaii's Avatar
maaii
maaii is offline
I actived Carplay of my Mini 2019 F54 entrynav2 (aka entryevo). This head unit needs fsc code to activated , you must to buy form dealer.
When you get fsc code, you can use esys to load in head unit.
  #94
Old 10-28-2019, 01:30 PM
kontak's Avatar
kontak
kontak is offline
hi,
so carplay can play in countryman f60 with 6.5 lcd (no touch);
build date is 19/9/2017.
6UM
thanks
  #95
Old 10-28-2019, 05:43 PM
maaii's Avatar
maaii
maaii is offline
Hi
You should check your Head unit first.
Method 1. Check by esys fsc status. if you can find out "appid 323 (0x143)", you can activate it for Carplay.
Method 2. Pull out your head unit and find out WiFi connector as below, if you can find wifi connector, you can activate Carplay.
  #96
Old 10-30-2019, 08:21 AM
MasAyinde's Avatar
MasAyinde
MasAyinde is offline
What is this full screen carplay wizardry?
  #97
Old 10-30-2019, 08:29 AM
GnFnRnBacon
iOS 13 supports full-screen CarPlay.
MINI headunits currently do not.
  #98
Old 10-30-2019, 08:41 AM
MasAyinde's Avatar
MasAyinde
But that F60 headunit supports it
  #99
Old 10-30-2019, 09:19 AM
GnFnRnBacon
Nope. MINI F60 headunits currently do not.
  #100
Old 10-30-2019, 09:36 AM
MasAyinde's Avatar
MasAyinde
So what’s the deal with the picture in post 90?
Quick Reply: F60 Carplay finally!
