F60 :: Countryman Talk (2016-2023) F60 Countryman discussion
F60 Countryman Cooper SE reversing lights
Old 04-19-2018, 02:34 AM
Birbilis's Avatar
Birbilis
Birbilis is offline
Can anyone please tell me how many reversing lights my Countryman Cooper SE should have illuminated on reversing (GR model)? Only the left one lights up white. There is a similar lens on the right side with a bulb clearly in it - this one does not illuminate!
Is that normal?
Old 04-20-2018, 11:53 PM
Birbilis's Avatar
Birbilis
Birbilis is offline
Nobody?
You can tell me about the US model, I suppose!
Old 04-21-2018, 01:09 AM
AnOldBiker's Avatar
AnOldBiker
AnOldBiker is offline
4th Gear - An Official NAM Greeter
I believe what your looking for is in this manual .. and you need to look at page 179.
https://www.miniusa.com/content/dam/...ner_manual.pdf
It shows there are two lights, one of each side, and the manual will show you how to change them out. I did this on my Countryman and it's not hard. Just be careful when taking the light bracket out so you don't screw it up. They seem sort of flimsy to me.
Old 04-21-2018, 10:32 PM
Birbilis's Avatar
Birbilis
Birbilis is offline
Indeed there are lamps in both tail-lights. They both light up as rear fog lights. But only the left one lights up white when engaging reverse.
What I’m looking for is whether this is normal or I have a bad lamp on the right side!
Old 06-21-2018, 01:35 PM
Birbilis's Avatar
Birbilis
Birbilis is offline
After some better checking, the bulbs in the lower clear window of each tail-light are looking completely different. Only The left one lights up white for reversing while only the right one lights up red for rear fog light. I suppose that’s the way it is designed.
McFred (01-18-2022)
Old 06-22-2018, 11:05 AM
StevePDX's Avatar
StevePDX
StevePDX is offline
I just had a co-worker check mine and both backup lights should illuminate while reversing. Ya may have a bad bulb.
Old 06-22-2018, 11:48 AM
Birbilis's Avatar
Birbilis
Birbilis is offline
That’s weird, I suppose it should give an error. Or maybe it’s different country wise.
Do you have the led headlights and fog lights?
Old 06-22-2018, 12:02 PM
StevePDX's Avatar
StevePDX
StevePDX is offline
Yes, I have the LED lights.
Old 06-24-2018, 12:44 PM
Birbilis's Avatar
Birbilis
Birbilis is offline
Europe spec cars (at least in Greece and U.K.) have only one taillight illuminate during reverse. Problem solved.
Old 06-24-2018, 02:19 PM
MrFunk's Avatar
MrFunk
MrFunk is offline
Sorry didn't see this till now.
Not sure why no-one responded - easy question... both should light up. You should have 2 reverse lights.
But if you're in EU then different spec to NA.
Old 06-25-2018, 07:02 PM
NBCGLX's Avatar
NBCGLX
NBCGLX is offline
OP, if you have the rear foglight option, then one of your reverse lights is replaced with the rear foglight. If you DON'T have the rear foglight option, then you should have two reverse lights.
McFred (01-18-2022)
Old 08-09-2021, 08:30 AM
varma1986's Avatar
varma1986
varma1986 is offline
The right side is designed to be a Fog Light as in Europe. Only the left is the Reversing light. If it is required by law in your country that both the sides need to light up, you need to get it coded as such by your dealer (or) your dealer can offer you a letter stating of such fact and seeking exemptions on the basis of manufacture/design.
Old 08-12-2021, 01:54 AM
kerwooddr's Avatar
kerwooddr
kerwooddr is offline
In the U.S., there is no requirement that a vehicle have two reversing lights. What is required is that all factory installed lights are operational. That does not include aftermarket lighting such as LED light bars, off-road high-intensity lamps, rally lights, etc.
medicdave
05-23-2013 06:16 AM
bilvrun
Electrical
05-18-2011 03:21 PM
mahendra26
Electrical
03-09-2010 02:10 PM
JerryTheTiger
05-09-2003 05:10 PM
AlexChalk
10-11-2002 11:43 PM
Quick Reply: F60 Countryman Cooper SE reversing lights
