F60 :: Countryman Talk (2016-2023) F60 Countryman discussion
F60 F60 Mudflaps
  #26
Old 05-29-2019, 08:33 AM
victoryrider's Avatar
victoryrider
victoryrider is offline
thanks guys
  #27
Old 05-29-2019, 10:21 AM
victoryrider
this is why I'm confused. I emailed my local Mini dealer about it and this was response I got:
Good afternoon Ed,
I looked into the mud flaps with our parts department, and unfortunately they will not fit with the JCW trim. If you have any further questions, please let me know.
Thank you,
James
Service Advisor
  #28
Old 05-29-2019, 10:50 AM
F56-JCDub's Avatar
F56-JCDub
F56-JCDub is offline
As long as you have the part numbers right, then the SA doesn't know what he's talking about.
https://www.realoem.com/bmw/enUS/sho...diagId=03_4061
victoryrider (05-30-2019)
  #29
Old 07-05-2019, 09:09 AM
Walrus's Avatar
Walrus
Walrus is offline
What width of moulding tape did you all use? 1/4" or 1/2"?
  #30
Old 07-05-2019, 09:34 AM
F56-JCDub's Avatar
F56-JCDub
The flaps came with its own 3M double-sided adhesive tape. The adhesive was already in place on the inside of the flaps, and I only had to remove the plastic and put it in place. It seemed like it was 1/4"
  #31
Old 07-05-2019, 09:45 AM
Walrus's Avatar
Walrus
Walrus is offline
I bought the ones from China, they don't come with tape.
These:
https://www.aliexpress.com/item/3284...3f7e4c4div6zyL
I ordered them June 19, and they showed up today.
  #32
Old 07-05-2019, 09:55 AM
victoryrider
mine came with tape already on it. I would say it was 1/4 inch not half.
  #33
Old 09-22-2019, 01:29 PM
Brainygadgetgirl's Avatar
Brainygadgetgirl
Brainygadgetgirl is offline
Ali Express Mud Flaps for 2019 F60 - awesome!
Just received these flaps for under $45 CDN from Ali Express:
https://s.click.aliexpress.com/e/Kl7zVuLA
Shipping to Canada took about 3 weeks. Quality is excellent and the fit is perfect. Unlike others who have talked about installing with tapes and adhesives, I used the included hardware. I doubt that Canadian winters would allow for anything other than screws and bolts to attach mud flaps.
I was able to complete the entire job with a few simple tools (hammer, pliers, flat and star head screwdrivers and a 5/16 ratchet and socket). I did not need to remove wheels or to jack car up. You should be able to manage this job if you’re willing to lie on the garage floor and get a little dirty. Have attached a few pics as the mud flap set does not come with instructions. All holes fit to what was already filled with a plastic blind rivet on the Countryman wheelwell. I did drill one extra screw (provided in kit) into the wheelwell trim on both front flaps. Flaps attach solidly and without gaps.
Not a bad little project for a Sunday afternoon - all in all took about an hour.
Underside of front wheel well; remove screw and save for installation of new front flap
Front flap; reuse blind rivet if possible; included black clip to fold plastic tab over behind the wheel trim and fasten by pushing on the black metal clip; drill in additional screws if desired for tighter fit
Front mud flap installed
Rear flaps- remove the two plastic blind rivets and slide metal washer over body trim, then fit flap and drill in the two new screws (included) - not shown - remove bolt from underside of wheelwell with 5/16 socket and reinstall through the mud flap through provided perfectly matched hole.
Side view of completed flap installation- I’d say they are a perfect match and fitment!
Rear flap installed
Front flap installed
1RavingLunatic (09-25-2019)
  #34
Old 12-07-2019, 08:37 PM
ny_yankee's Avatar
ny_yankee
ny_yankee is offline
So the stock rivets that are there already. If I push pin through can I reuse the same pin. ? Or should I purchase these.
Amazon Amazon
  #35
Old 12-08-2019, 03:13 PM
Mini03Tiger84's Avatar
Mini03Tiger84
Mini03Tiger84 is offline
https://www.amazon.com/uxcell-a16072.../dp/B01LDJ0UPQ
I was able to reuse the pins. Be careful that you don't push it all the way through. I lost one to the voids behind the wheel well. I used a ink pen tube as a replacement. Just cut to length.
  #36
Old 03-24-2022, 05:15 AM
NBCGLX's Avatar
NBCGLX
NBCGLX is offline
Rallyarmor is another company to look at, we carry them and they make much larger ones then the factory MINI ones.
Do you have them for the F60? I feel like I couldn’t find them on your site when I looked.
  #37
Old 03-24-2022, 06:09 AM
ECSTuning is online now
Received 1,964 Likes on 1,764 Posts
Hello,
https://www.ecstuning.com/b-rally-armor-parts/v-mini/
Right here, just search in shop by brand then select MINI.
  #38
Old 03-27-2022, 05:54 PM
NBCGLX's Avatar
NBCGLX
NBCGLX is offline
Hello,
Bummer, so nothing specific to the F60? Odd that Rally Armor makes them for the Honda Civic, but not the Countryman (or any MINI, for that matter). Any idea how the universal ones attach and look when installed?
  #39
Old 03-30-2022, 02:16 PM
Yea, it looks good and you can cut to fit.
Here if is the R60 way it looks to give you an idea
https://www.northamericanmotoring.co...mud-flaps.html
  #40
Old 09-06-2023, 10:36 AM
Just an update here are the mud flaps and the install PDF for the F60 MINI Countryman Mud flaps attached for the MINI ones.
https://www.ecstuning.com/Search/Sit...h/82162410137/
and
Old part 82162410138 now 82162467102
https://www.ecstuning.com/Search/Sit...h/82162467102/
File Type: pdf
  #41
Old 09-10-2023, 06:37 AM
cuppajoe's Avatar
cuppajoe
cuppajoe is offline
Thanks @ECS Tuning. Just ordered front and back.
ECSTuning (09-11-2023)
  #42
Old 09-11-2023, 08:03 AM
Welcome.
  #43
Old 09-25-2023, 02:59 PM
cuppajoe's Avatar
cuppajoe
cuppajoe is offline
Installed the mud flaps. The blind rivets didn’t seem to hold very tightly, but that is probably installer error.
I used some
push rivets push rivets
instead and those seem to work pretty well.
bluonyx (09-25-2023)
genik
02-01-2017 07:00 AM
actualsize37
11-02-2014 08:56 AM
Mini_Chan
05-10-2007 03:56 PM
AeroJammin
10-06-2006 09:34 PM
sleepy_nokkie
11-22-2004 01:55 PM
Quick Reply: F60 F60 Mudflaps
