F60 :: Countryman Talk (2016-2023) F60 Countryman discussion
F60 Lowering Springs
Old 02-16-2018, 02:34 PM
cmartyna's Avatar
cmartyna
cmartyna is offline
Question Lowering Springs
Anybody have lowering springs for the F60 yet? Really would like to lower it and get better handling. My F60 does have Dynamic Damper Control too so needs to be compatible...
RECOMMENDATIONS??
Old 02-17-2018, 04:52 AM
MrFunk's Avatar
MrFunk
MrFunk is offline
I'm not sure you're going to improve the handling a ton with a mild drop. I also think you may ruin the ride if you'd only doing springs which I'm sure you would in order to preserve the dynamic dampers. Your spring to damper rate will be WAY off with any kind of stiffer spring, especially if doing an aggressive lowering. I'd suggest instead look at a rear sway and perhaps solid end links if they make em for these... better tires can go a long way also (the oe's are garbage IMO). I actually think it rides pretty good in sport mode.
I'm all about lowering and improved handling but this just doesn't seem like the right vehicle for that if you ask me.
To answer your question - I haven't seen springs for it anywhere.
Old 02-17-2018, 06:12 AM
cmartyna's Avatar
cmartyna
cmartyna is offline
I am not too worried about a stiffer ride. My last MINI (Cooper 4 door hardtop) was lowered with NM lowering springs and it felt like a MINI should. It handled sooo much better too and looked so much better! MINIs should be that way from the get go since they are known for Go Cart Handling! So I am not too worried about "ruining the ride". LOL My goal is to make the car look better and get rid of some wheel gap, improve the handling slightly, and to have a stiffer ride. The F60 is a big vehicle so any drop I can imagine would improve it. I just have been unsuccessful trying to find any kind of aftermarket springs...
Old 08-30-2018, 06:23 PM
Propak's Avatar
Propak
Propak is offline
H&R has them for the f60 now. Supposed to give a 1.2” drop front & rear.
Old 09-12-2018, 08:04 PM
bluonyx's Avatar
bluonyx
bluonyx is offline
Come on, someone order them and give us a before and after write up!
Old 09-13-2018, 01:00 AM
ND40oz's Avatar
ND40oz
ND40oz is offline
KW has coilover kits that come with EDC deactivation modules, if you want to go that route. It's surprising they don't have a plug and play DDC kit yet, maybe with the new X2 M35i that'll encourage them to produce one.
http://www.kwsuspensions.com/product...-102200bp.html
http://www.kwsuspensions.com/kw-susp...-352200bp.html
Old 09-14-2018, 08:04 PM
Propak's Avatar
Propak
Propak is offline
My HR lowering springs came in on Thursday and i will be installing them on Saturday (9/15). I’ll post some before and after pics.
Evlkarl (09-15-2018)
Old 09-16-2018, 07:33 PM
Propak's Avatar
Propak
Propak is offline
Did a quick video of my F60 after the H&R lowering spring install. Already a 1.5” drop and I think it still will settle a bit more. Looks great but now it may need some bigger wheels and/or some spacers to get it looking just right. Heres the link.
. Putting together an install video that will be up later this week.
The following 3 users liked this post by Propak:
ApexF60SE (02-02-2024), Evlkarl (09-16-2018), TheOriginalKonky (09-17-2018)
Old 09-16-2018, 08:42 PM
Evlkarl's Avatar
Evlkarl
Evlkarl is offline
Thanks for the Video the car looks good. Here are some pics of a F60 that B and B from Germany spruced up a little with 20" wheels. By any chances can you please post the product/model number of the H@ Springs. Thank you.
Timothy Watkins (07-17-2019)
Old 09-17-2018, 02:47 PM
Propak's Avatar
Propak
Propak is offline
That's a good looking F60. I'd like to get the wheel and tire specs on it. I'll do some research. The model number for the H&R Lowering springs is 28790-1. I picked them up from Tirerack although ECS has the available as well. https://www.tirerack.com/suspension/...=Cooper+S+ALL4
Old 09-17-2018, 03:47 PM
Evlkarl's Avatar
Evlkarl
Evlkarl is offline
Propak, Thank you for the quick reply.
Old 09-17-2018, 05:44 PM
Propak's Avatar
Propak
Propak is offline
Here's a 30 minute video of the install. I'm no videographer but you'll get the idea!
Old 09-18-2018, 05:54 AM
ECSTuning is online now
Received 1,965 Likes on 1,765 Posts
Looks good. The F60 has so much lift to it when you do lower you still have some wheel gap. Lower profile/larger wheels and spacers will help that.
Old 09-18-2018, 05:51 PM
Propak's Avatar
Propak
Propak is offline
That's gonna take some math to figure out. All that offset & backspacing stuff is critical to figuring out all the spacer & tire/wheel size issues when going to 20" wheels.
Old 09-18-2018, 08:45 PM
Evlkarl's Avatar
Evlkarl
Evlkarl is offline
Propak, here is the link to BB Tuning in Germany maybe you can send them an Email. If you have no luck PM me and I will try to get in touch with them since I am fluent in German.
http://www.bb-automobiltechnik.de/de...tartseite.html
here is the info for the email address
http://www.bb-automobiltechnik.de/de...men/index.html
Old 09-20-2018, 06:28 PM
Propak's Avatar
Propak
Propak is offline
Looks like 225/35-20’s on the 20 inch rims. The 19” JCW rims have a 47mm offset which I assume fit without a spacer. I would think a 20” rim would need a 52mm offset. Just guessing tho.
Evlkarl (09-20-2018)
Old 11-05-2018, 12:18 PM
LiL Stinker's Avatar
LiL Stinker
LiL Stinker is offline
Will these work on a 2018 Counryman S 2 wheel drive?
Old 11-06-2018, 10:58 AM
https://www.ecstuning.com/Mini-2018-...nsion/Springs/
Spring Options Above^^
LiL Stinker (11-06-2018)
Old 11-30-2018, 07:41 AM
TheOriginalKonky's Avatar
TheOriginalKonky
TheOriginalKonky is offline
Originally Posted by Propak
Did a quick video of my F60 after the H&R lowering spring install. Already a 1.5” drop and I think it still will settle a bit more. Looks great but now it may need some bigger wheels and/or some spacers to get it looking just right. Heres the link. https://youtu.be/iDeTSWB4Npk
Did they settle any more from the first pictures you posted? If so, do you happen to have a new picture you can post? TIA
Old 11-29-2019, 08:28 AM
ny_yankee's Avatar
ny_yankee
ny_yankee is offline
Now all you have to do is push those baby's out a touch. Spacers.
I have been racking my brains on getting taller tires to fill out my new 19 CMS but you've inspired me to just lower it! I just ordered the H&R's, I did also purchase new wheels that I'll be swapping out the P7's with, with a et40. I was looking for another tire also (softer) but to be honest the P7's aren't that bad. I'll post up soon.
Old 12-11-2019, 11:21 AM
ny_yankee's Avatar
ny_yankee
So how much of the ride was lost from stock springs to H&R's
Old 12-11-2019, 12:34 PM
Just a head up we have one system on sale for coilovers on the F60/F54
https://www.ecstuning.com/b-kw-suspe...rs/180200bnkt/ limited quantities 30% off. and for DDC you will need these. https://www.ecstuning.com/b-kw-suspe...e/68510477~kw/ Some people have told us that they just disconnected the DDC system and never got an error.
Just an option if you want more then springs
Old 01-04-2020, 11:26 AM
WeBad_Paceman's Avatar
WeBad_Paceman
WeBad_Paceman is offline
Were you able to retain factory alignment specs without any camber plates or anything with these lowering springs?
Old 02-03-2021, 10:28 AM
Jason Martin's Avatar
Jason Martin
Jason Martin is offline
I called H&R and they said the ones they make are only for the F60 All4. there is too much conflicting information online, I called Mini Mania and they say they have them I just do not spend the Money and they won't work.
Can anyone clarify this for me?
Thanks in advance!
Jason
Old 01-24-2024, 04:52 AM
KalenaR's Avatar
KalenaR
KalenaR is offline
Nice looking Countryman. We just bought a 2019 Countryman S. We are planning on lowering it as well. Thank you for posting the videos. I noticed your caliper covers. Could you tell me where you bought them? I went up to the MGP site and the MINI only goes to 2015 when I do a vehicle search. Thank you for your help. Have a blessed day!
cattywampus_mini
Suspension
21
09-01-2015 08:04 PM
vicj
01-27-2013 08:24 AM
Dwight Walhood
Suspension
14
03-01-2011 08:58 AM
enfuegodp13
Suspension
19
04-15-2009 05:40 PM
BanzaiGTti
Suspension
03-30-2004 12:20 PM
Quick Reply: F60 Lowering Springs
