F60 What did you do to/with your CM today?
#76
I ordered my JCW Countryman today! Melting Silver, black roof, black stripes. Wife is PISSED! But since I spent way too long in Syria then Iraq, then Kuwait, and then maybe Iraq again while she spends my $$$, I'm doing what I want...And the kids are so excited that they picked the color! I made sure it has the wife theft deterrent system, a third pedal, I now have a toy again!! Pick it up when I get home! I'm too excited and I tried checking the production number already
#77
#79
#80
When I replaced my stock S grille with the black S grille, it looked like (though admittedly I didn't look closely) the S was actually molded as part of the grille honeycomb, not a separate 'badge', so I would've assumed the base model would just be the honeycomb with no spot or placeholder for an S/JCW 'badge'.
#81
#82
Yes, Dinan Elite. Followed instructions on website and install is no more than an hour. Easiest access to remove battery cable is to lift off rubber trim that seals to the hood and then remove the panel below the windshield that runs the width of the car above the battery. Once the rubber trim is lifted this piece slides forward (toward front of car) and then you can simply lift it up allowing you to put a socket on the battery terminal clamp. Very simple once you figure it out.
Take the extra time to route and secure the wiring harness nicely. As you can see, I located the module on the plastic panel next to the positive battery boosting post. I ended up removing the red plastic cover and turning it 180 degrees to allow a little more room in the area. The recommended placement in the instructions is for an F56 and on the F60 the area is a little different and not as large.
And...? Driving impressions with the tune?
#83
To put things in perspective, I did not expect the tune to make the pug run like a greyhound...that isn't the purpose of the car. That being said the Dinan Elite certainly gives the pug a shot of Red Bull.
The car is primarily my wife's daily driver but I have had the opportunity to drive it around town and on the highway since the install. The torque is improved and there is no downside to anything that I can tell. For me, this is the way the car should come from the factory.
FWIW my wife constantly says how much more she enjoys driving the Countryman than the MB GLC that she had the past two years. Relatively speaking the car's performance is now at least as good (and probably better) than the GLC300 but not in AMG43 territory...but again that wasn't the point.
Is the car difference noticeable? Yes.
Is the car more fun to drive? Yes.
Did it meet my expectations? Yes.
Is it worth it? Absolutely!
On another note I must say that since turning off ASD with Bimmercode the car is much quieter (is that a word? more quiet?). Either way I find it surprisingly quiet for the type of vehicle and more enjoyable to drive. Once we get back to our place in BC where the 3 dr Cooper S resides it will be the first thing I switch off. I know some people enjoy the extra sound and find it engaging but it should really be a feature that can be switched off or on from within the settings of the car from factory.
MrFunk (01-07-2018)
#84
1RavingLunatic (01-07-2018)
#85
Same for me - the car is the wife's but I drive it when we are out as a family which is several times a week. I'll order this very soon.
Can you tell me where I can turn off ASD in Bimmercode?
#86
You don't have to go into expert mode to do this on Bimmercode. Once you have hooked up and connected to Bimmercode app it is one of the first options you can toggle on or off.
#94
#95
Didn't even get a chance to find out. They said the hole was too close to the side. They also said they didn't have the Bridgestone tires in stock (Because they're too new) and said they can order me 2 new front tires (Not Bridgestone) since the tread pattern has to be the same (PA laws) $580 dollars my ***. I found the Bridgestone Runflat on tirerack for $214 shipped. I'll get it on Monday and get it installed at my local Tire shop for $15. That **** should be illegal for them to rape you like that. The guy next to me was bitching be cause his car was in for service (an oil change) and the advisor said the tech suggested you get 4 new spark plugs "the total out the door is $235". The guy laughed it off and said, I'm good, I can do my own spark plugs.
#98
