Drivetrain NEW RELEASE: F5x/F60 MINI S/JCW Carbon Fiber Intake System
Old Nov 5, 2019 | 11:49 AM
Dinan Engineering's Avatar
Dinan Engineering
Part Number: D760-0051
Applications:
  • 2015-2019 BMW F48 X1 xdrive28i/sDrive28i
  • 2017-2017 BMW F39 X2 xDrive28i/sDrive28i
  • 2014-2019 MINI F55/F56/F57 Cooper S/JCW
  • 2015-2019 MINI F54 Clubman S/JCW
  • 2016-2019 MINI F60 Countryman S/JCW
Product Page(s) / Pricing: bit.ly/MINI-F56-CAI
Recommended Install Time: 0.5 Hours
Release Date: Available Now!
Description: The Dinan carbon fiber intake for the MINI B46/B48 engines (as well as the BMW F48 X1 and F39 X2) is tantamount to an exercise in efficiency. Given a confined space with limited options and an even smaller budget-- create an intake that provides power, sound, and throttle response in an aesthetically pleasing package. While not the easiest of things to accomplish, we embarked upon the task with our team of engineers determined to provide a solution.
Through a bevy of flow bench testing it was quickly determined that the biggest hindrance to improved flow on the stock intake was the factory snorkel. Unfortunately, the snorkel also was the piece that would cause the largest increase in cost to a potential kit. As a result it was quickly abandoned as a potential area of improvement. Instead, attention was turned to finding a way to introduce a secondary inlet for additional air flow. With limited room to work with, traditional secondary ducting was not possible. This in turn led to multiple experiments being conducted on the effectiveness of a possible open air inlet on the upper lid. With different shapes, locations, and sizes of openings being tested, the goal was to ensure that the added secondary inlet did not cause any unwarranted side effects such as an increase in air temps in the system. This is commonplace with open air intake systems where lots of overheated engine bay air is utilized in the intake tract. The results of these tests showed that a 12 sq./in. opening for additional air on the opposite side of the upper lid from the engine provided a perfect balance of additional volume to assist the factory snorkel all the while not causing an increase in turbo inlet temperatures. This was the case regardless of testing conditions (single/multiple gear pulls, constant speed, 0-100mph runs, etc.).
With more air being pulled into the system, throttle response is improved and additional power is realized in the form of max gains of +5 HP / +5 ft-lbs of torque. The secondary air inlet also allows the intake system to be more audible so the turbo spool and BOV can be appreciated. A stark difference from Dinan's traditional fully sealed systems where induction noise is not nearly as recognizable. Not to be outdone by the increased power and sound, the system is made of immaculate carbon fiber so it looks the role as well. The end result of an optimized lid, an improved filter and thorough testing, yields an incredibly efficient and cost effective solution that you will be hard pressed to beat.
Features/Benefits:
  • Maximum gain of +5 HP and +5 lb-ft of torque @ 5000 RPM
  • Enjoyably louder, sportier sound
  • Improved throttle response
  • Large carbon fiber air box lid allows increased volume of air to be utilized taking advantage of the free flowing filter
  • Bell-mouthed side inlet creates a secondary air intake source with optimal flow characteristics and no increase in intake air temperature
  • Free flowing injection molded Air Mass Meter housing
  • Quick and easy installation
Video:
Old Nov 5, 2019 | 12:15 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Interested buyers are going to want to see some Dyno results showing gains.
Old Nov 7, 2019 | 05:59 AM
NBCGLX's Avatar
NBCGLX
Any particular reason this isn't also being advertised for the B36 3-cylinder? Other aftermarket intakes fit it just fine.
Old Nov 7, 2019 | 11:16 AM
Dinan Engineering
Simple answer is we have never tested it on the 3-cylinder. Looking at ETK's the only 3 cylinder we would be nearly certain it would work on would be the Base Countryman since it uses the same lower box, snorkel, filter, and MAF as the B46/B48. Barring something else physically interfering it should work. Other 3 cylinders utilize a different snorkel (although the same lower box) so they most likely would work as well but until we physically fit one we wouldn't list it as compatible. Do proper vetting and all that...
If any 3 cylinder owners are near us in Auburn/Opelika AL area feel free to PM me and we can potentially work out a quick fitment, etc.
Old Jul 16, 2022 | 06:35 AM
dbrescia's Avatar
dbrescia
2021 f60s
Is there an intake that fits the 2020+ LCI F60 S all4?
Old Jul 18, 2022 | 04:55 AM
Dinan Engineering
Not at present. Been in the queue for a long time but finding a donor test vehicle has been much more difficult then it should be. Given up on that endeavor and are in the process of purchasing a new fleet vehicle instead so there should finally be movement on it again.
Josh/AWE
Sep 5, 2020 01:30 PM
Dinan Engineering
Nov 21, 2019 09:59 AM
bahman
Mar 20, 2017 04:04 AM
Feb 19, 2016 02:52 PM
Mot4rD
Aug 4, 2008 09:31 PM
