F55/F56 B46 Engine or...
Most of the guys running the NM on the B46 use the low setting w/o any issues. All seem to report excellent performance and big improvement over stock.
Lots of threads discussing the NM vs. the Burger and settings/octane/ethanol/E85, etc.
I opted for the JCW tune through MINI. I am quite satisfied w/ the result (although way more expensive than either the NM or Burger), it comes w/ a full warranty and a very nice exhaust.
NM Module works and AFIK has always worked well with the B46. I've been running mine since a week after buying the car 9/15. I ran it on high with 93 octanes with good results. After installing the JCW Pro Tuning Kit I had to drop it back to low because the high setting was actually causing the engine to cut back on boost. I haven't tested it ye. but I believe if I use 100+ octane I can go back to the high setting.
I like all the JCW appointments also.
I left the "S" on the rear boot, but did a grille swap and side markers w/ the JCW logos. Also added the scuttles and mirror caps too.
Next Mini will likely be a full JCW. I like the looks but can do w/o all the suspension and brake upgrades since I'll never track the car. I also prefer the front fascia of the S to the JCW. I had my brake ducts painted Chili Red and I think it really makes the front end pop.
My only concern about going w/ a full JCW is finding it not having the straight line pep my S has w/ the JCW tune. The tune actually provides better torque (which is where acceleration comes from) than the stock JCW.
I'd like to see the 2018 F56 JCW produce the numbers of the 2017 JCW Clubman. I'd then have zero reservations of trading up.
Take a look at Dinans module, works on both engines.
on
b46 is the lower emission with a slightly different turbo and supposedly slightly better MPG than the b48.
Same basic architecture. In BMW's, they are tuning and changing compression to get more HP, as is the case with MINI JCW.
Basically, for all essential components, same wine/different label.
Good B46 description here: http://www.bimmerfest.com/forums/sho...d.php?t=874330
b48 vs b46
I am contemplating buying a new JCW. Does the JCW have a version of the b46 engine?
Only mentioned it as way more expensive for those paying dealer MSRP. My dealer price matched. I found the kit on-line for around $1600-$1800 (can't remember exactly now)....which I thought was fair considering the full warranty coverage, badging, and BT exhaust.
