F55 Wheel/tire options
Old 03-15-2017, 07:28 PM
golferji's Avatar
golferji
golferji is offline
I have a F55s 2017 with dynamic damper (big mistake).
Running 18x7 stock rims with a 2015 Runflat. I cant lower the car because of the DDC.
Looking to move to a wider wheel/tire combo. I asked the dealer and was surprised when they did not know - said to call tire rack.
Is it possible to do a 18x8 and 225 wide - has anyone tried?
Or should I just go with 215/40?
I drove a 17 Clubman ALL4, and it took corners MUCH MUCH better than my car. Could it be the 225 tires???
Going crazy with this and am afraid I will be stuck with a poor handling car.
Old 03-15-2017, 09:41 PM
Zazoh's Avatar
Zazoh
Zazoh is offline
Many folks complain of runflats in general. In the research I've done, prior to purchasing car, a few folks indicated they didn't like the handling of the 18" tires on the F55. I don't remember the specifics though.
And, ironically the DDC should improve cornering. What's happening in the corners ?
NM, I saw your other thread. Sucks. I wouldn't dump anymore money in to the car until your sure what the issue is. Maybe take it somewhere for a look over.
Old 03-31-2017, 03:56 PM
camptown's Avatar
camptown
camptown is offline
my set up will be as follows and will get installed by the end of April.
2016 F55S, non JCW brakes
Factory DDC
Neuspeed RSE10 18"x7.5"
+45 offset
225/40/18 tires
and just in case I have a 3mm spacer to install if needed.
So I will post up pictures and details once completed. I have read others are running a 225 wide tire with an 18" wheel. Plus Neuspeed said it would fit but Tire Rack won't touch this set up since they don't sell a wheel with the above specs, but they did confirm the tire will fit the wheel.
Good Luck
Old 04-23-2017, 09:06 PM
golferji's Avatar
golferji
golferji is offline
Camptown, can you send those pics???
Old 04-24-2017, 03:03 PM
camptown's Avatar
camptown
camptown is offline
I will once they are installed which should be in mid May
