F55/F56 Would this exhaust hack work?
Old 02-19-2017, 06:28 PM
Mini_Vinnie's Avatar
Mini_Vinnie
Mini_Vinnie is offline
Moderator
I really want to get rid of that 2nd cat after the downpipe. My Mini has the upgraded John Cooper exhaust so ideally I don’t want to buy a new exhaust.
Do you think adding an after market mid pipe could work?
https://www.ecstuning.com/b-borla-pa...ipe/60565~bor/
Old 02-19-2017, 08:52 PM
djtomy's Avatar
djtomy
djtomy is offline
Seems like a lot just for just a mid pipe. I'm in the same situation but have a catless DP before it. Mine sounds almost perfect with the factory JCW system, but I'm wanting something different, especially if there is any kind of performance to gain.
Old 02-20-2017, 03:39 AM
Mini_Vinnie
Moderator
Originally Posted by djtomy
Seems like a lot just for just a mid pipe. I'm in the same situation but have a catless DP before it. Mine sounds almost perfect with the factory JCW system, but I'm wanting something different, if there is any performance to gain.
Changing my DP is another option too. My local shop is a little hesitant cutting the 2nd cat out and if I do eventually sell my Mini it might be tougher with it cut out
Old 02-20-2017, 06:54 PM
mattkosem's Avatar
mattkosem
mattkosem is offline
Try it and let us know. Would be nice to have an off-the-shelf option here. Even has a resonator. Might sound pretty nice.
--Matt
Old 02-21-2017, 03:11 AM
Mini_Vinnie
Moderator
--Matt
Yeah, my thoughts exactly. I just cant tell if the JCW connector is a slip fit or a flange. I havent gotten down under my car yet to tell
Old 02-21-2017, 05:22 PM
vetsvette's Avatar
vetsvette
vetsvette is offline
Moderator
Plus, you've gotta pull the belly pan off the front before you can see it.
Old 02-22-2017, 03:20 AM
Mini_Vinnie
Moderator
Shoot, I forgot about that.
Old 02-24-2017, 04:58 AM
trentiles's Avatar
trentiles
trentiles is offline
No you don't. I have been under my S a lot due to recently installing a downpipe. You don't need to remove the belly pan to see the connection between the downpipe and 2nd cat piping. That connection is past the subframe and is clearing visible without removing anything.
Unless the JCW is different but I doubt that.
Old 02-26-2017, 12:28 PM
mattkosem's Avatar
mattkosem
I believe that depends on location. US spec cars definitely have a flange. Euro cars (maybe ROW too?) have slip fit at the DP. I'll nab one of those in a heartbeat if it'll mate up to the JCW Pro exhaust
--Matt
Old 02-26-2017, 05:02 PM
Mini_Vinnie
Moderator
--Matt
In a perfect world it will ............ im going with having to have a flange welded on
Old 02-26-2017, 06:01 PM
MarcoPolo's Avatar
MarcoPolo
MarcoPolo is offline
fwiw, craigsix is selling his Remus midpipe with us-spec adapter for $175 shipped. that's disgustingly cheap.
https://www.northamericanmotoring.co...290769-fs.html
Old 03-11-2017, 06:35 PM
Mini_Vinnie
Moderator
Exhaust hack complete and it is a success! Milltek catless and resonator-less midpipe with my JCW catback
Old 03-12-2017, 02:30 PM
mattkosem's Avatar
mattkosem
Nice! Direct fit after that cut toward the rear? I'm afraid to ask, but how much louder is it with no res and no second cat?
Old 03-12-2017, 05:12 PM
Mini_Vinnie
Moderator
So it was a direct fit after we expanded the midpipe a bit. I decided to weld it though. Originally it was going to be a slip fit but I wanted to practice welding
To be honest, it isnt that much louder over stock at all. My wife would have been the first person to tell me it was loud and that wasnt the case. We drove this morning (16 degrees in MPLS) so if it wasnt loud then I dont think it will get loud.
The pops and bangs were louder and more frequent so that was an awesome sound. I noticed a little deeper rumble too. Im pleased with it
Ill make a video of the sounds tomorrow
Old 03-18-2017, 01:44 PM
craigsix's Avatar
craigsix
craigsix is offline
good to see it has a home. nice work,
Old 03-18-2017, 07:37 PM
Mini_Vinnie
Moderator
Thanks again buddy!
Old 03-08-2018, 06:13 PM
mattkosem's Avatar
mattkosem
Well, I have one of these sitting here. It's a slightly smaller diameter than the JCW Pro exhaust (2.5"). The front section is about 10" longer than the front section of the JCW pro exhaust (~42" vs 32" from flange to end). The pipe coming in/out of the resonator is at a slight angle, but it seems like it should end straight down the center of the exhaust well. Seems like it should bolt up using the center JCW clamp if it is shortened a bit and expanded. I'm not too hip to adding smaller pipe than I have, so I think I'll send it back.
--Matt
