F55/F56 Will 225/50/17 tires fit on my stock 17” rims?
Old Oct 7, 2020 | 04:53 PM
Mrshooby's Avatar
Mrshooby
I have a set of these winter tires of the above size from my paceman.
Now we have a 2016 Cooper S hardtop and I’m wondering if I can fit these tires onto my stock 17” rims.
Hoping someone might have the answer. I know it will increase the overall diameter slightly but I don’t know if this will cause issues.
Old Oct 8, 2020 | 06:50 AM
NBCGLX's Avatar
NBCGLX
That size is considerably larger overall than the factory 205/45-17 tire size. I mean, the 225/50-17 tire is almost 2” bigger in diameter alone, which is almost guaranteed to rub the fender, suspension, or both (particularly when the suspension is compressed at all).
Old Oct 8, 2020 | 08:36 AM
rtowell's Avatar
rtowell
225/45-17 on factory rims is pushing it. The rims are only 7" wide so they are on the narrow side. Also, you will most likely have clearance issues on the front struts ... some 215's do not clear. You can always use spacers, but spending on size they can affect steering feel.
I think the 215/45-17 is a better choice for three reasons - they are not too wide for the rims, they probably will not rub, and they are lighter than 225s by up to two pounds.
Some of the autocrossers on this forum are using 225s, but they are also using wider wheels with appropriate offset to avoid rubbing.
Old Oct 16, 2020 | 02:31 PM
josuaitor's Avatar
josuaitor
Hello from Spain.
I've 225 45 17 Good Year Eagle F1 Assymetric in my Cosmos Spoke 499 Jet Black 7" wide stock rims witthout any problem. 225 is the maximum recommended width for 7" wide tires.
PD: This is my first post in thys forum.
Old Oct 16, 2020 | 02:40 PM
cmt52663's Avatar
cmt52663
Mount one, and try it - front and back.
I reckon you'll have a pretty good rub on the rear, at 10 and 2.
But mebbe. Worth a try as you have them....
Cheers,
Charlie
laxpimp6903
Tires, Wheels, & Brakes
Feb 12, 2010 07:34 AM
forumware
Sep 7, 2006 04:26 PM
bowhunter8
14
Feb 22, 2006 12:19 PM
kyle00
Feb 15, 2006 11:11 PM
