F55/F56 Portable jump starter question
Old Jul 12, 2020 | 12:02 PM
hfh64's Avatar
hfh64
Quick question…looking at purchasing a portable jump starter for our 2019 F55. All the jump starter instructions are written for use with exposed battery terminals. The F55 has a Positive “Starting Aid Terminal” and a Negative body ground or the Special Nut near the strut tower.
I’m assuming these two locations will function the same as the actual battery terminals for use with a portable jump starter? Just wanted to be clear (owner’s manual only addresses conventional jump start cables).
Thanks in advance!
Old Jul 16, 2020 | 05:29 PM
TVPostSound's Avatar
TVPostSound
Correct
Old Jul 18, 2020 | 09:30 PM
michaelo's Avatar
michaelo
Old Jul 19, 2020 | 08:46 AM
hfh64's Avatar
hfh64
Thanks for the help!
Regarding the combo device, I had considered the compressor combo but will likely get separate jump starter and compressor pieces for two reasons. I’m concerned about compressor failure and then being stuck with a half functioning device.
The major reason is for space limitations, and the realization that my F55 does not have a manual hatch release inside the car (dash button is electric like the hatch)…if the battery’s dead, I’d rather reach for a small device in the glovebox than pull down the back seat, climb in the back, possibly unload the trunk, etc.
*At the risk of sabotaging my own thread (!), the F55 is actually driven by my daughter, whereas I drive a 2014 MCS Roadster. Another curious trunk design…it does have a manual release under the latch; would be helpful if you were trapped in the trunk (?), but completely unreachable through the bulkhead passthrough access. I had thought of retrofitting a cable release from one of the G1s (Detroit Tuned has made a kit for it), but I’ll likely just attach a flat nylon luggage strap and lay it on the trunk floor with the buckle near the bulkhead passthrough in case I need to pull the trunk release for a dead battery.
AvianMan
Nov 3, 2015 11:00 AM
eggserronius
Sep 12, 2014 08:57 AM
gknorr
Sep 11, 2011 08:38 PM
jeffm5150
Classic Mini Talk
Apr 3, 2009 04:29 AM
Haggardsk8er
Jul 20, 2008 07:00 PM
