F55/F56 Help sourcing engine mounts
Old Aug 1, 2019 | 05:12 AM
Nage's Avatar
Nage
Hi all,
I need some help sourcing one of the engine mounts. The one I need is the upper passenger side. I believe it's oil filled or hydraulic because it's cracked and leaking.
The issue I am having is just about everywhere I'm searching has the mount for the s model, not the base. When they do have the base model, it's for the automatic transmission. I want to (need to) change this as I'm out of the warranty period. I guess I'm just not as good at searching as I thought...
What I need specifically is for a 2015 Cooper 2 door hard top base with a 6 speed manual transmission. EDIT: after looking at some install manuals, I see I need to replace the engine mount to cylinder head bolts. For the mentioned model of mini, any help with where I can source the bolts too?
I have included pictures of the mount in question that I need help finding.
Old Aug 1, 2019 | 06:27 AM
I_Forge_KC's Avatar
I_Forge_KC
The mount/bolts:
https://www.realoem.com/bmw/enUS/sho...06#22116875628
Old Aug 1, 2019 | 06:45 AM
Nage's Avatar
Nage
Awesome! That helps a lot. Is there a specific Torx set I need? its there a difference like standard and metric, or is torx a torx?
Old Aug 1, 2019 | 06:53 AM
I_Forge_KC's Avatar
I_Forge_KC
Those are just E-Torx (external). Something like this would be fine.
https://www.harborfreight.com/7-pc-1...set-67898.html
Old Aug 1, 2019 | 07:14 AM
Nage's Avatar
Nage
Seriously appreciate all the help. This has been a struggle for me all morning. My searching capabilities I guess need some work!
Thanks again!
Old Aug 2, 2019 | 06:39 AM
sgscomps's Avatar
sgscomps
You can order the mount from your MINI dealer. This way your getting the correct part. The bolts will need to be torqued.
Old Aug 5, 2019 | 06:50 PM
J_L's Avatar
J_L
@Nage come over to this thread that's going on... some more info over there. Would love to hear how the install goes once you're done! I need to do mine too, same issue. Oh, same car btw- S with MT.
https://www.northamericanmotoring.co...placement.html
I hadn't really thought of replacing the bolts, but I guess it's cheaper to do it right than to have them back out down the road...
Old Aug 7, 2019 | 11:43 AM
michaelo's Avatar
michaelo
"...This has been a struggle for me all morning..."...
Posting here trying to find a part is more effort than just calling the dealer to order it.
Apr 7, 2014 07:44 PM
MR_X
R55 :: Clubman Talk (2008+)
Dec 9, 2011 08:52 AM
second to none
Feb 5, 2008 06:04 PM
FUEGO
Tires, Wheels, & Brakes
21
Oct 12, 2006 11:28 AM
katmeho
General Discussion
Mar 9, 2006 08:13 PM
