Hood/Tailgate emblems stick on?
So on the 2019 F56's are the hood/tailgate emblems stick on or stick/bolt on?
I was going to black them out, but now I'm thinking of removing them completely. Just don't want to remove them and find out there's two holes underneath them. |
I know it doesn't help but my 16 were both stick on's
No that totally helps, thank you.
Stick on,
They have little alignment pins on the back dependant on what model you have. On the front, i think no pins, on the back there are pins. To remove the old ones a hair dryer (heat it up) and floss works great. we just landed some of the new ones for the F56 and others: Hood F56 51142465241 https://www.ecstuning.com/b-genuine-...m/51142465241/ https://c1552172.ssl.cf0.rackcdn.com/1322312_x800.webp Trunk F56 51142465242 https://www.ecstuning.com/b-genuine-...r/51142465242/ https://c1552172.ssl.cf0.rackcdn.com/1322455_x800.webp |
Awesome as usual, I couldn't find them anywhere but overseas. I'll be placing my order soon.
2019 F56 front emblem has pins. I had to pull mine off to add stripes a few weeks ago.
I actually ordered the black LCI badges a few days ago for my '15 and they should be here Saturday. Does anyone have the part number or a listing for the boot handle? I've been told due to being different the LCI badge won't fit on the pre-LCI boot handle but I can't seem to find it.
It is hard to tell. So my SO has a 2019 convertible and I have a 2015 Hardtop, and I actually just measured them. They are exactly the same length and height. The only concern there is for me is that the new boot handle is flat, while the pre-lci has a recessed around the badges. As a note, I have already replaced the front, and it had two position holes in it. It will have to be filled if you want to remove it.
El-Grunto, my expectation is that you will not need the updated boot handle, as I am certain it will fit correctly. With that being said, let me know how the rear goes. As I am planning to pick it up soon. |
They are stick with pins, front and back. I put LCI ones on my '15. The rear latch on the LCI does not have the indent. Outmotoring has black cover kit that you stick on over logos. They also give you a choice of color surrounds (vinyl) for the MINI circle.
https://cimg9.ibsrv.net/gimg/www.nor...9f5f38d2d7.jpg |
I have a pre LCI handle and the New Blackline Genuine MINI Badges, i can check. :)
So it works and sets down and follows the curve on the trunk grip handle. The badge has a curve also. Its sets a little higher in the stock location of the old Chrome badge, But still aligned in that indent. Sets flat to it and position is a tad higher, maybe a millimeter or so.
Badges are the same size, i think the alignment pins on the back just set more towards the middle on black (post LCI version.. If you are really picky on alignment you could just notch or remove the back pins and realign it. |
Originally Posted by SFMCS
(Post 4464300)
https://cimg7.ibsrv.net/gimg/www.nor...6cab308803.jpg
https://cimg9.ibsrv.net/gimg/www.nor...60f98d1fb2.jpg https://cimg0.ibsrv.net/gimg/www.nor...4158cbe2f2.jpg The part number for the rear trunk lid grip in black with reversing camera is: 51137489756. I bought the 2 black emblems and the grip and fitted them to my 2016 JCW. I think it looks great. The emblems have aligning pins and adhesive. |
Originally Posted by kfmuller
(Post 4464781)
(Post 4464781)
(Post 4464308)
Originally Posted by Agbullet25
(Post 4467208)
Just curious why you bought the new trunk lid grip? Prefer the flat look versus the notched one that came on our pre-LCI cars?
(Post 4467213)
So then the line on the website about possibly needing to get the LCI smooth-faced trunk grip isn't accurate since you verified the badges fit the pre-LCI recessed trunk grip?
(Post 4467213)
UPDATE: Back in stock again and we added more emblems for the clubman, countryman , and the NEW " Cooper S" emblem that can also be used on the Cooper, just dont apply the "S"
MINI Cooper S Model Lettering - Piano Black 51142465245 https://www.ecstuning.com/b-genuine-...l/51142465245/ https://c1552172.ssl.cf0.rackcdn.com/1333748_x800.webp 51142465243 https://www.ecstuning.com/b-genuine-...l/51142465243/ https://c1552172.ssl.cf0.rackcdn.com/1333749_x800.webp And "Clubman" Model Lettering For Clubman - Piano Black51142465246https://www.ecstuning.com/b-genuine-...l/51142465246/ https://c1552172.ssl.cf0.rackcdn.com/1333755_x800.webp |
OK, so now what do you suggest using to stick them back on with? I don't want to lose mine in the carwash.
They come with double side 3m tape already on the new ones from MINI. When you install new ones make sure the surface is clean and no wax in the spot you install. I use a little windex and mare sure if you have an old emblem on there before that the gummy left over 3m double sided tape residue is gone, WD40 helps and then clean again with windex.
Just an update:: 36122469709
We now have MINI Floating Logo (like Rolls Royce) Center Caps. These are for the F54-F60 Cars that take the normal center cap with exposed lugs. We even tested it to fit on Team Dynamics wheels also, they fit a bit loose. Update ** You might need to add a couple wounds of tape for them to hold into place. We had a video on IG of the spinning of the caps, but IG is down and not working right now. https://www.ecstuning.com/b-genuine-...d/36122469709/ https://c1552172.ssl.cf0.rackcdn.com/1387840_x800.webp Like this but for MINI: https://cdn.shopify.com/s/files/1/00...g?v=1560828178 |
I see you have the JCW version on B/O.
(Post 4480454)
We now have MINI Floating Logo (like Rolls Royce) Center Caps. These are for the F54-F60 Cars that take the normal center cap with exposed lugs. We even tested it to fit on Team Dynamics wheels also. We had a video on IG of the spinning of the caps, but IG is down and not working right now. https://www.ecstuning.com/b-genuine-...d/36122469709/ https://c1552172.ssl.cf0.rackcdn.com/1387840_x800.webp Like this but for MINI: https://cdn.shopify.com/s/files/1/00...g?v=1560828178 |
