F55/F56 Rear tyres rubbing on inner felt lining after lowering
Old Sep 20, 2016 | 10:40 AM
sootyvrs's Avatar
sootyvrs
I have 17x8 ET45 running 215/45/17 tyres and I've had no problems with anything rubbing until I had passengers in the rear and a full tank of fuel...
The rear is lowered around 35mm so not slammed under the arches although with rear arches it probably lowers another 10mm at the rear when passengers in.
Every time I cornered I could hear something rubbing. When i stopped to look I could see that the rear tyre was was rubbing on the felt lining which seems to be pertruding out a little which compounded the problem I suspect...
I have pushed the lining back in place as tight as it can go and will see if it happens again next time... Failing that I may cut some of the felt away unless there is some method of holding the felt tightly down.
Anyone else have this problem or found a solution?
Old Sep 20, 2016 | 12:09 PM
honderpilot's Avatar
honderpilot
Pics of your set up?
Old Sep 20, 2016 | 03:08 PM
vetsvette's Avatar
vetsvette
Moderator
17X7.5 ET40 with 215/45X17 tires. Lowered 1.5" all around with NM springs. I've been running this combo for almost 4 months with no problems.
Old Sep 20, 2016 | 03:31 PM
sootyvrs's Avatar
sootyvrs
Here you go
Attached Thumbnails Rear tyres rubbing on inner felt lining after lowering-dsc02560.jpg
Old Sep 20, 2016 | 03:33 PM
sootyvrs's Avatar
sootyvrs
Thanks.. I wonder if it's just the rear arch lining worked loose... Will monitor if it happens again...
Been reading on BMW forums that many have just used a stanley knife to cut a bit away if needed. Might try that if it still happens
Old Sep 20, 2016 | 06:15 PM
02fanatic's Avatar
02fanatic
According to vetsvette your wheels & tires should be about the same re: push out, so it's either your tires or the ride height causing the issue. I'd prefer the 7.5" wheel width but I'd think what you have should work based on what I've seen others running. No two cars are identical I suppose.
Old Sep 20, 2016 | 06:45 PM
honderpilot
Originally Posted by sootyvrs
Here you go
Looks great! I'm thinking on running a similar set up. Let us know if it happens again/ if you figure out the issue
Old Sep 21, 2016 | 01:16 AM
sootyvrs's Avatar
sootyvrs
There have been others running a similar setup without issues so I suspect it's just my car.
I did notice when i inspected it after the rubbing started that the arch liner at the rear is a little loose as if it's not clipped on securely. I must have pressed the arch liner towards the arch approx. 10-15mm before it was flush. I wonder if there are any clips that keep it tightly in place?
Thanks.. Will keep you updated although I don't carry passengers too often... Might find something heavy to put in the boot (Have a spare set of wheels) to see if I can replicate the problem...
Old Sep 21, 2016 | 05:44 AM
02fanatic's Avatar
02fanatic
According to realoem.com the wheel arch covers do have clips (upper & lower). You might want to check that out.
Old Sep 21, 2016 | 05:48 AM
sootyvrs's Avatar
sootyvrs
Thanks, I did look here -
http://www.realoem.com/bmw/enUS/show...diagId=51_9650
Couldn't make out if there's a clip at the upper part of the trim which is where it came loose.
Old Sep 21, 2016 | 02:07 PM
sootyvrs's Avatar
sootyvrs
Just an update to say that pushing the felt trim and tucking it back in to the arches worked as ive just tries it with passengers.
Will keep an eye if it stays in place but its a relief that no major bodywork mods are needed.
Old Sep 21, 2016 | 04:42 PM
02fanatic's Avatar
02fanatic
That's good! Hope it holds....may have just been a rare occurrence!
Old Sep 22, 2016 | 01:36 AM
sootyvrs's Avatar
sootyvrs
I think the trim might have been moved from my OCD cleaning routine as I use a Wheel Woolies brush to scrub the felt lining every time I wash the car.
That possibly might explain it not being in place tightly. Fingers crossed..
vulkandino
Sep 20, 2016 07:41 AM
CoolioMcPimp
Sep 19, 2016 05:48 PM
kramerv
Tires, Wheels, & Brakes
Sep 18, 2016 07:44 PM
Rfifty6
Sep 17, 2016 11:47 PM
haxmed
Sep 16, 2016 03:45 PM
