F55/F56 How do I remove the trim to get to brake reservoir?
Is there a trick to remove the trim? Do you just undo the fasteners and unscrew the two nuts?
Edit:
I flushed my brake fluid with ATE type 200.
The trim came off with little effort. Undo the fasteners with a coin or mailbox key. Undo the two nuts. Unclip the flat clip on the left side.
pull from the left corner. The vent hole on the right side comes out from the air duct.
The bmw brake reservoir filter needs to be pried from the gap. Use a thin metal with no sharp edge to pry it off from the reservoir. The filter spins have rounded barbs.
I kept it clean by wrapping it with a mechanics paper towel while I worked on the car.
Edit:
A lot of bubbles came out.
However, it did not get rid of the soft brake feel.
The brake comes on late. That is the problem with my MINI.
The first 1/2 pedal travel does very little. The second 1/2 of the pedal travel makes the brake work much harder. New pads are in order...
Aren't you still under warranty? Take the car in and make the dealer fix it!
Sometimes it takes a couple bleeds to get all the air out. Whats does you rotors look like , glazed ?
RudeJoe
29
05-31-2023 08:01 PM
RudeJoe
11-02-2016 04:17 PM
Joeygonz
05-21-2016 10:03 AM
sannweinstein
Tires, Wheels, & Brakes
05-18-2016 09:41 AM
sannweinstein
05-18-2016 08:57 AM
