F55/F56 Coded 2TB Sports Automatic Transmission into F55 Justa
Old May 4, 2022 | 10:57 AM
  #26
TVPostSound's Avatar
TVPostSound
Originally Posted by TechTurbo
Noted I am the same with you, a F57 S with 205. My question is along the benefits of updating 205 to 2TB; are we saying it shifts faster no matter you are in the regular (D) or sport program (S1, S2, S3...) transmission?
And do we know which ECU needs to be VO code? Thanks a lot.
You mean which module of the DME?
Its been a minute suave I used e-sys.
You'll need to look up from the BMW boards.
Old May 4, 2022 | 11:33 AM
  #27
TechTurbo's Avatar
TechTurbo
Yes which module to VO code if you can share your experiences.
Old May 4, 2022 | 07:39 PM
  #28
TechTurbo's Avatar
TechTurbo
Update - I replaced the vehicle option of 205 with 2TB and coded the EGS ECU. I can confirm that the only change it made as a result is Sport T/M under 3000 went from disable to enable.
On the test drive itself I did not notice the transmission shifted any faster / better under D normal mode. In transmission sport mode (lever to the left) I felt the lower gears are a bit longer with equivalent performance. I did not experience any jolt / shifts abruptly that @Imperial reported above. For now, I will keep the coding and keep an eye if the car throws any code or act abnormally.
Old May 28, 2023 | 09:17 AM
  #29
RjamesB8's Avatar
RjamesB8
bcman
Electrical
Jul 5, 2014 08:27 PM
Freedog
Electrical
Feb 6, 2014 07:54 AM
OreoPanda
Electrical
Aug 25, 2013 11:55 AM
early_apex
May 9, 2008 01:29 PM
dkamp
R55 :: Clubman Talk (2008+)
41
May 1, 2008 11:28 AM
