F55/F56 Racing Seat rails/mounts
Old Dec 14, 2015 | 08:48 PM
Coopercaba's Avatar
Coopercaba
Hey everyone I am currently looking for information on bucket seat rails or mounts for the f56. I have looked everywhere but all I see out there are for the R models.
Has anyone retro fit anything? Or also ran into this problem? Thank you all :D
Old Dec 15, 2015 | 02:38 PM
TheBigNewt's Avatar
TheBigNewt
I haven't seen anyone post about retrofitting other seats on the F56. You are correct, it's been done on the R56, including Recaros similar to mine (which were a factory option).
Old Dec 16, 2015 | 11:20 AM
Harvey_97's Avatar
Harvey_97
I have fitted aftermarket bucket seats to mine. Not many have done it yet. Here's a pic
Racing Seat rails/mounts-image-1839189619.jpg
Old Dec 16, 2015 | 04:54 PM
Coopercaba's Avatar
Coopercaba
Attachment 118976
Looks awesome!! What rails did you use to mount the seats? Any info is greatly appreciated
Thank you :D
Old Dec 16, 2015 | 04:59 PM
Ryephile's Avatar
Ryephile
Attachment 118976
What, or did you do about the airbag system?
Also +1 the mounting brackets. Custom or is someone doing bolt-in?
Old Apr 27, 2016 | 05:22 PM
Coopercaba's Avatar
Coopercaba
Does anyone have any info on seat rails for our F56? Still looking -_-
Old May 16, 2016 | 12:17 AM
Coopercaba's Avatar
Coopercaba
So months after researching I finally pulled the trigger on some seat floor mounts. Made by Macht Schnell. http://machtschnell.com/competition-liteweight-floor-mounts-racing-seats-e46-e85.html
They were a direct Bolt on, I didnt need to machine or grind anything down.
Old May 16, 2016 | 12:38 PM
TheBigNewt's Avatar
TheBigNewt
The seats look great. The mounts look like they came out of an airplane lol. Is that the speaker?
Old May 16, 2016 | 10:51 PM
rmcintos's Avatar
rmcintos
Those somewhat look like car baby seats and look rather uncomfortable, to be honestly.
Old May 17, 2016 | 02:51 AM
VolcanicOrangeF56S's Avatar
VolcanicOrangeF56S
Are you throwing any airbag codes?
Old May 19, 2016 | 11:53 AM
Coopercaba's Avatar
Coopercaba
They do look like a big baby car seat, but as long as i am not being thrown around at the track and i am comfortable on my daily 100 mile commute im okay with that!
"Are you throwing any airbag codes?"
I am throwing a driver restraint error code but i am told by my shop foreman, that i am able to get that light erased when i bring the car in. I have not yet proven that to be true or false so we will see. i do plan to remove the passenger side stock seat very soon as well so hopefully i can remove the light.
Old May 19, 2016 | 12:26 PM
ASKtheteach's Avatar
ASKtheteach
I know Scroth makes quick fit racing harnesses for first and second gen cars. Do they make them for third gen cars?
Old May 19, 2016 | 02:32 PM
Not yet, last time I talked to them. I will ask them again. We carry the Gen 1 and gen 2 ones.
Old May 13, 2017 | 12:09 PM
atlantaorange's Avatar
atlantaorange
has anyone tried a 1st or 2nd gen schroth setup in a f56? the setup seems pretty much the same. I have a setup for my e30 that is really for an e36. seems like as long as the harness will clip into the stock receptacles it would work. im going to test fit mine in the next few weeks. will be taking the f56 to the track for the first time in june..
Old May 13, 2017 | 05:35 PM
vetsvette's Avatar
vetsvette
Moderator
Sparco seats, rails, and modified Sparco R53/R56 bases. Still haven't solved my driver/passenger restraint warning problem yet.
Old May 14, 2017 | 07:45 PM
hadjiikong's Avatar
hadjiikong
I have fit my gen 2 schroth 4 point belts into the F56 without any issue.
Old May 15, 2017 | 04:08 PM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
[QUOTE=vetsvette;4301330]Sparco seats, rails, and modified Sparco R53/R56 bases. Still haven't solved my driver/passenger restraint warning problem yet.
The resistor didnt work?
Old May 16, 2017 | 10:11 AM
vetsvette's Avatar
vetsvette
Moderator
The chassis to seat connector is a strange piece. Can't tell what's what with it. Wasn't the kind of plug/setup I was expecting. I need a good wiring diagram before I can do anything.
Old May 19, 2017 | 07:08 PM
Mini_Vinnie
Moderator
Interesting. There has to be a way to bridge that or trick it somehow. Can you delete the light with a scanner tool?
Old May 20, 2017 | 12:39 PM
vetsvette's Avatar
vetsvette
Moderator
I'm sure there's a way, but I need a schematic before I can do anything. If nothing else, when I have said schematic and can ID the individual wires in the chassis harness, I'll remove the connector and solder/heat shrink the resistors directly to the wires. I won't be going back to the stock seats so no reason to keep the connector.
zenbuilder
Dec 21, 2015 08:40 AM
RicWRX
Dec 18, 2015 08:58 AM
bealehere
Dec 14, 2015 12:38 PM
u238
Dec 10, 2015 01:23 PM
JustinG60
Dec 8, 2015 02:40 PM
