Mini/MINI BUILDS Showcase your Build Talents.
Lightly Modifying My F56
Old 02-21-2018, 02:21 PM
vetsvette's Avatar
vetsvette
vetsvette is offline
Moderator
Road trip to Sneed4Speed yesterday. Chris removed my Delrin shift **** and installed the new Billet Aluminum Billy Club for me. The extra weight is a +. Only downside was the only way we could get the Delrin **** off was with a saws-all. Hated to ruin a perfectly good shift ****, but ya gotta do what ya gotta do. Also installed a set of S4S side splitters/ I still have a little finishing work to do on the side splitters, but over all a productive day. Finally finished vacuuming all the scrap and plastic "sawdust" out of the interior a little while ago.
Attached Thumbnails Lightly Modifying My F56-fullsizeoutput_53a.jpeg   Lightly Modifying My F56-fullsizeoutput_53c.jpeg   Lightly Modifying My F56-fullsizeoutput_538.jpeg
The following 3 users liked this post by vetsvette:
Idonthaveaminiyet (07-23-2018), Mini_Vinnie (02-21-2018), ryanschram (02-22-2018)
  #202
Old 02-22-2018, 01:14 PM
ryanschram's Avatar
ryanschram
ryanschram is offline
Man, those side splitters look great. Now I REALLY want them.
  #203
Old 04-03-2018, 05:14 PM
vetsvette's Avatar
vetsvette
Moderator
Spent about eight or nine hours working on the Mini today.
First we removed the OEM Sport Suspension with NM lowering springs. (these will be in the classifieds sometime this week) Then we replaced the stock down pipe with a Milltek Catless DP. Installed a new lower engine mount with the yellow Powerflex Bushing W/Black inserts. Installed a new CravenSpeed E-Brake handle to match my billet S4S shift ****.
To be honest, 99.9% of the work was actually performed by my Son in Law and an old buddy from the USAF. My Buddy has a lift in his garage so it made the work (for them) a lot easier. After reading stories about people not being able to get both the OEM heats shields re-installed I figured I would do a header wrap (yep, I did this) and hit it with a few coats of high temp silicon spray. Turns out my SIL got all the heat shields re-installed without a hitch. Now I just need to put a few more miles on it to burn off the residue from the darn header wrap and silicon spray. Suspension is fine so far. Ride height is ~ same as it was with the NM springs. I'll put some miles on it this week and get the alignment checked. I'm really happy with the improved shifting since installing the Powerflex engine mount and I love the way the Metal E-Brake and shift **** complement each other.
Attached Thumbnails Lightly Modifying My F56-fullsizeoutput_5ac.jpeg   Lightly Modifying My F56-fullsizeoutput_5b1.jpeg   Lightly Modifying My F56-fullsizeoutput_5b2.jpeg   Lightly Modifying My F56-fullsizeoutput_5af.jpeg   Lightly Modifying My F56-fullsizeoutput_5b3.jpg
Lightly Modifying My F56-fullsizeoutput_5ad.jpeg   Lightly Modifying My F56-fullsizeoutput_5a6.jpeg
The following 4 users liked this post by vetsvette:
aubcar (04-03-2018), bluonyx (02-11-2019), ECSTuning (07-23-2018), Mini_Vinnie (04-03-2018)
  #204
Old 04-04-2018, 07:46 AM
USA-RET's Avatar
USA-RET
USA-RET is offline
It's amazing to think we essentially started out w/ the same cars, brother...
You've completely transformed yours inside and out. I can only imagine the speed and handling you've gained over last couple of years.
How do you like the Dinan Stage 1 compared to the NM? Big difference?
Have you ever done a 0-60 or 1/4 mile run? I do understand that we don't buy a Mini for straight line performance or 1/4 mile runs, but it can be an effect way to measure gains as we add tunes and performance up-grades.
I'm guessing you have no plans to sell or trade for the foreseeable future (and why would you )
  #205
Old 04-04-2018, 08:26 AM
vetsvette's Avatar
vetsvette
Moderator
Hey man. I have no idea how the Dinan performs. I never got a chance to install it. I sent it back the day after it arrived and ordered the ByteTronik Tune. Where it was a hot little beast when I was running the JCW Tune w/NM module, the BT Tune turned it into a certified fire breathing close relative of Godzilla!
By the way, I'm still interested in your brake duct scoops. I think we can make a deal. Still have plans to have my CF wing installed before MOTD. The new mounts are out for welding and powder coating. This month is going by Fast! And, no, I have zero plans to ever part with this car. Just ordered a set of Goodyear Eagle F1 Asymmetric 3 summer tires so I'll have new stickier rubber for the Dragon this year.
  #206
Old 04-04-2018, 01:48 PM
TVPostSound's Avatar
TVPostSound
TVPostSound is offline
I see stock front sway bar links on the ground, what did you replace them with???
  #207
Old 04-04-2018, 02:22 PM
vetsvette's Avatar
vetsvette
Moderator
Oh Man! I knew I forgot something!
JK. The BC Racing kit comes with shorter links.
ryanschram (04-05-2018)
  #208
Old 04-25-2018, 07:46 PM
vetsvette's Avatar
vetsvette
Moderator
Installed a ByteTronik hidden dash cam today. Streams directly to your phone or iPad via WiFi. Very easy to wire because it just plugs into the OBD port. Has capability for up to 32gb micro sd card in the camera itself. Lots of different settings that can be done within the app. Cost- $110 shipped.
I figured this would be a good way to record some of the runs that my Grandson and I make at MOTD this year. Truly a stealth installation.
The link is to mini_vinnie's writeup on the camera, with pictures.
https://myredmini.com/byte-tronik-re...mirror-camera/
Mini_Vinnie (04-26-2018)
  #209
Old 04-26-2018, 12:34 AM
pw1114's Avatar
pw1114
pw1114 is offline
Hardwire version of that cam, which is what I have, so u don't have to block your OBD port ( and that so you can keep recording when the car is at the dealer for service).
https://www.aliexpress.com/item/Dash...311.0.0.55wrHV
  #210
Old 04-26-2018, 12:46 AM
vetsvette's Avatar
vetsvette
Moderator
Not worried about the OBD port. I got the cable with the through put plug. I have three items plugged into the port now. The version you linked is nice, but I wanted to go with easiest install. It's not for security reasons so I don't need it on always. Main reason I got it was to record the runs my Grandson and I are going to do at MOTD.
  #211
Old 04-26-2018, 07:33 AM
USA-RET's Avatar
USA-RET
USA-RET is offline
Looking forward to seeing some of those videos posted here, buddy. PDR in the C7 was nice for that very reason. MOTD is early May this year, no?
Just keep it between the ditches and the shinny side up unless you're wanting a 1,000,000+ hits on the video.
  #212
Old 04-30-2018, 10:53 PM
MiniF55's Avatar
MiniF55
MiniF55 is offline
Thread still going strong! Love it. Minis at the Dragon is around the corner.
  #213
Old 05-14-2018, 05:05 AM
trentiles's Avatar
trentiles
trentiles is offline
How did the car perform and dyno at MOTD with the BT tune?
  #214
Old 07-22-2018, 08:50 AM
vetsvette's Avatar
vetsvette
Moderator
Disappointed, but still a work in progress.
  #215
Old 07-22-2018, 08:55 AM
vetsvette's Avatar
vetsvette
Moderator
Installed new Cravenspeed shift well cover. 5 minute job, and I’m happy with the results.
Still waiting for my new RMW coil overs
Attached Thumbnails Lightly Modifying My F56-5055a4e7-0cc2-4ffd-87ee-fcc3fd20d6ce.jpeg
Ikim (05-12-2023)
  #216
Old 07-22-2018, 01:24 PM
Zix's Avatar
Zix
Zix is offline
Would you still recommend the BT tune?
  #217
Old 07-22-2018, 02:01 PM
vetsvette's Avatar
vetsvette
Moderator
Oh yeah. The car has a lot more power than the dyno showed. I think it was a combination of bad gas, altitude, and the people running the dyno. Only one other car had higher numbers and he was disappointed too. I’m ordering the Stage 2 tune as soon as the weather cools off.
The following 2 users liked this post by vetsvette:
easter (07-23-2018), Zix (07-22-2018)
  #218
Old 07-30-2018, 09:20 PM
Knovako2's Avatar
Knovako2
Knovako2 is offline
Great mods. Red roof really makes the adrenaline rush!
  #219
Old 07-30-2018, 09:42 PM
vetsvette's Avatar
vetsvette
Moderator
Thanks.
  #220
Old 07-31-2018, 05:39 AM
USA-RET's Avatar
USA-RET
USA-RET is offline
Hey Whitey, Have you run another Dyno on your car since the last time? Interested to hear if the one at the Dragon was a fluke. Your car should be producing some really good numbers w/ all the mods.
  #221
Old 07-31-2018, 06:34 AM
vetsvette's Avatar
vetsvette
Moderator
Nope. No public access Dyno locally. It’s running fine on the street, what little I’ve been able to drive it since MOTD.
  #222
Old 07-31-2018, 11:05 AM
Idonthaveaminiyet's Avatar
Idonthaveaminiyet
Idonthaveaminiyet is offline
Very well done on your build
  #223
Old 08-22-2018, 12:02 PM
vetsvette's Avatar
vetsvette
Moderator
Received my new RMW coil overs yesterday. This is Jan’s first set made for the F56. Hope to get them installed soon.
Afrothunder_72 (08-25-2018), CallMeRacerB (08-31-2018), Revolution Motor Works (08-22-2018)
  #224
Old 08-22-2018, 02:18 PM
TVPostSound
Sweeeeet!
I wants those end links.
  #225
Old 08-22-2018, 04:26 PM
02fanatic's Avatar
02fanatic
02fanatic is offline
Mighty purdy!!
Quick Reply: Lightly Modifying My F56
