F55/F56 F56: Under the Bonnet
Old Oct 13, 2015 | 07:28 PM
  #26
Ryephile's Avatar
Ryephile
Originally Posted by FlyByMike
'Tis a Beautiful thread - underhood pics, OBD, and engine theory(?)
I have a few questions about the OBD in post #20 ...
What is the OBD command that equates to "commanded torque" ? I'm guessing it's one of these throttle commands ?
SAE.TP
SAE.APP_R
SAE.TP_R
SAE.TP_B
SAE.APP_D
SAE.APP_E
SAE.TAC_ACT
What value are you using for "Brake Specific Fuel Consumption" ? Is this for a plain MCS or a JCW version ? I have a '014 MCS.
-Mike
Those appear to be software-specific (DashCommand?) abbreviations and not the normal J1979 PID's. The F56 outputs two PID's for accelerator pedal, one for the throttle body itself, and one for calculated commanded torque. I'll have to double check but I believe the "commanded torque" I put in the 2nd graph in post #20 is PID 61.
I'm using the rough correlation that 10 lb/min = 100 HP, roughly assuming 0.55 lb/hr/hp is the BSFC. Without extensive and hugely expensive engine dyno cell experiments to map BSFC vs. load and RPM, we won't know any more precisely without scoring some fairly confidential data. There isn't going to be any significant difference in BSFC between the Cooper, Cooper S, and JCW, given their essentially identical combustion chambers.
I hope that helps.
Old Oct 14, 2015 | 02:01 PM
  #27
caiken's Avatar
caiken
Best. Thread. Ever.
Old Oct 14, 2015 | 05:10 PM
  #28
FlyByMike's Avatar
FlyByMike
I hope that helps.
It does help Thanks.
Yes, I use Dashcommand but I look back and see I had those SAE.XXX from way before I had DC - when I programmed a PalmPilot to be my water temp gauge. Nonetheless, I don't think PID 61 is available on DC. My biggest complaint is I can't add 'custom' PIDs dagnabbit.
DC suggests BSFC of .55 so I suppose I'll stick with that.
Thanks again,
-Mike
Old Oct 14, 2015 | 07:06 PM
  #29
hammerhands's Avatar
hammerhands
Those names seem to be similar to a program called EFILive. I wonder if Dashcommand is related to that program or if there is something in the j1979 documentation for using those sae. names.
I think there is some documentation.
61h is "Driver's Demand Engine - Percent Torque" TQ_DD
Which isn't available, I guess. Dashcommand lists this as SAE.TQ_DD
This is the only pdf I can find, so far.
http://read.pudn.com/downloads122/do...8-25Ballot.pdf
Old Oct 14, 2015 | 07:22 PM
  #30
Kinetic89's Avatar
Kinetic89
Awesome post! Very informative
Old Oct 15, 2015 | 04:23 AM
  #31
g34343greg's Avatar
g34343greg
lots of great info here!
if you're looking for more ideas on things to document here, how about a run through the gears in the 3 different drive modes while datalogging?
Also, any ideas on what the car is doing to prevent itself from gaining speed with the cruise control set going down a steep hill? I can feel something going on, but I'm not sure if it's applying the brakes for me or doing something with the valvetronic for increased engine braking to hold the set speed.
Old Oct 15, 2015 | 08:36 AM
  #32
Ryephile's Avatar
Ryephile
Great suggestion. I'll do that. It will be interesting to see the commanded torque versus pedal angle. I'm willing to bet the ignition and fueling is identical between modes, however the boost control strategy is likely different.
The cruise control actually uses the friction brakes according to BMW's press release, but it would also be interesting to observe that deceleration rate change and if any engine parameters are modified. Keep in mind that OBDII is just a guideline; we can't be sure if the "actual throttle angle" is the throttle body or the valvetronic, or some arbitrary combination of both being output to the OBDII.
Old Oct 15, 2015 | 08:50 AM
  #33
Ryephile's Avatar
Ryephile
Ok here's a big one. This is torn directly from tim330i's post in the new BMW F48 X1 section on Bimmerfest.com, I did not put this together, only re-host the pictures. It is very relevant for the MINI because the X1 shares the same platform and engines as the MINI.
Originally Posted by tim330i
The all new F48 BMW X1 is arriving in dealership with an all new engine. The BMW B46 inline 4 cylinder engine replaces the N20 4 cylinder found in the previous X1 as well as much of the BMW lineup. The N20 was a great engine but was not universally loved, complaints diesel like vibrations and engine racket were the prime offenses to American based BMW owners use to the silky smooth 6 cylinder engines.
In a never ending quest for more performance and efficiency the N20 is being retired and the B48 takes it's place. The B46 is part of the new BMW B family of engines, we dive into what makes this 2.0 liter TwinPower inline 4 special.
The new engine generation is mainly characterized by lower fuel consumption and fewer exhaust emissions (ULEV II). To achieve low fuel consumption, a map-controlled oil pump, characteristic map thermostat and injection system with direct-rail and electric arc wire-sprayed cylinder barrels, among others, are used. All engines also receive an automatic engine start-stop function and intelligent alternator control as a further EfficientDynamics measure.
Due to the similarities between the B38 3 cylinder engine and B46 4 cylinder engine some images shown are of the 3-cylinder engine.
TwinPower Turbo Technologies
BMW-TwinPower-Turbo-Technologies by Ryephile, on Flickr
TwinPower Turbo is a commonly misunderstood term, often being confused with twin turbo, especially as it was introduced around the time BMW discontinued the twin turbo N54 engine. TwinPower does not mean twin turbo, in BMW nomenclature it is the umbrella term that means the following technologies are used:
  • VANOS
  • Valvetronic
  • Direct injection
  • Turbocharging
Crankcase / Engine Block Design
BMW B46 engine block crankcase by Ryephile, on Flickr
Characteristics of crankcase:
  • Heat-treated all aluminium crankcase made from AlSiMgCu 0.5
  • Electric arc wire-sprayed cylinder barrels
  • Weight-optimized main bearing cap of crankshaft with embossing teeth
  • Closed-deck design
  • Deep Skirt
  • Oil ducts for the use of a map-controlled oil pump
  • Support of counterbalance shaft(s) in cored tunnel
Closed-deck design
With the closed-deck design, the coolant ducts around the cylinder are closed from above and provided with coolant bore holes. This design is mainly reserved for BMW diesel engines. Due to the high combustion pressures in the diesel engine, a greater degree of rigidity is required in order that the forces can be safely absorbed. As the gasoline engine uses the same unfinished cast part as the diesel engine, it also benefits from this robust design.
Cooling concept of cylinder head
The B46 engine has a cylinder head with cross-flow cooling. In the case of cross-flow cooling, the coolant flows from the hot exhaust side to the cooler intake side. This has the advantage of providing uniform heat distribution in the overall cylinder head. Loss of pressure in the cooling circuit is also prevented.
Cylinder head gasket
In order to satisfy the high demands of the B46 engine, a triple-layer spring steel gasket is used as the cylinder head gasket.
Electric arc wire spraying
The cylinder walls of the B46 engine are coated with electric arc wire spray (LDS). In this procedure a conductive metal wire is heated until it melts. The melt is then sprayed onto the cylinder barrels at high pressure. This layer of ferrous material is roughly 0.3 mm thick, extremely wear-resistant and facilitates an efficient transfer of heat from the combustion chambers to the crankcase, and from there to the coolant ducts
Counterbalance Shafts of B46 Engine
BMW B46 counter balance shafts by Ryephile, on Flickr
Due to the operating principle of the piston engine, undesired oscillations occur at the engine housing when driving, which can be transmitted to the vehicle interior. To counteract this negative effect, BMW has already been installing so-called counterbalance shafts in more recent engine generations. Up till now, their role was to cancel out free inertia forces and therefore increase ride comfort. In addition to the inertia forces, so-called 'free moments of inertia' also exist, which can also adversely effect ride comfort. Depending on the engine design and number of cylinders, varying degrees of free inertia forces and free moments of inertia occur.
The B46 engine has two counterbalance shafts which rotate at twice the speed of the crankshaft. The gears of the counterbalance shafts have 48 teeth. The gear of the crankshaft has 96 teeth.
Timing Chain, VANOS and Valvetronic Components
BMW B46 engine timing chain by Ryephile, on Flickr
On of the bigger changes on the B46 is the location of the cam shaft timing chain drive. Typically found on the front of the engine, the B family of engines has the chain drive on the transmission side. The inertia of the transmission at this end of the engine significantly reduces the rotary oscillations and also therefore the loads acting on the chain drive.
Note the two different chains that make up the cam drive chain. In the diesel engines, the high pressure fuel pump is driven by this intermediary gear setup. On the gasoline engines the high pressure fuel pump is located on top of the engine so a simple gear transfer sprocket is used.
To facilitate VANOS repairs the VANOS solenoid valve actuators on the B46 are not mounted to the cylinder head, but in the cylinder head cover. Presumably the cylinder head cover (valve cover) can be removed to change the solenoid so the entire engine does not need to be dropped. Additionally the mounting of the VANOS solenoid valve actuators has also changed. They are no longer bolted on, but are attached to the cylinder head cover using a bayonet fitting and retaining clips.
VANOS
With older VANOS systems, such as that used in the N55 engine, the VANOS units were controlled by separate VANOS solenoid valves integrated into oil ducts in the cylinder head. The oil ducts in the cylinder head are reduced and the adjustment speed is increased by using a VANOS solenoid valve unit and a mechanical VANOS central valve, which is located inside the VANOS unit.
The valve overlap times have a significant impact on the characteristics of the engine. An engine with smaller valve overlap therefore tends to have a high maximum torque at low engine speeds but the maximum power which can be achieved at high engine speeds is low. The maximum power achieved with a large valve overlap on the other hand is higher, but this is at the expense of the torque at low engine speeds. The VANOS provides a solution. It makes a high torque possible in the low and medium engine speed range and a high maximum power in the higher engine speed ranges. A further benefit of the VANOS is the option of internal EGR. This reduces the emission of harmful nitrogen oxides NOx, particularly in the partial load range
Valvetronic
The Valvetronic has been further developed for use in the new Bx8 engines. A distinguishing feature of the VVT4 is the Valvetronic servomotor is located outside of the cylinder head. Valvetronic comprises a fully-variable valve lift control and a double VANOS. It operates according to the principle of throttle-free load control. With this system, a throttle valve is only used to stabilize the engine operation at critical operating points and to ensure a slight vacuum for the engine ventilation. A very small vacuum can be produced in the intake pipe by slightly tilting the throttle valve, which allows treated blow-by gases to be introduced into the intake port during naturally-aspirated engine operation.
[size=3]Oil Filter[/size]
BMW B46 engine oil filter by Ryephile, on Flickr
Due to the construction space, the oil filter housing is suspended in the transverse mounting. The inspection is carried out from the bottom of the vehicle. Using an oil drain plug the Service employee can drain the engine oil from the oil filter module before opening the oil filter cover.
Cooling System
BMW B46 cooling system by Ryephile, on Flickr
In order to protect the thermally loaded engine components, the engine oil and the transmission oil from overheating, they are cooled using coolant. A mechanical coolant pump circulates the coolant in the cooling circuit. The heat quantities introduced to the coolant are emitted to the ambient air again using a radiator. An electric fan assists the radiator output. The coolant in the B46 engine is mainly circulated via a mechanical coolant pump. Several engines are also equipped with an electrical overrun pump which maintains a trickle of coolant to the bearing seat cooling system of the exhaust turbocharger.
Special features of the B46 cooling system
  • Coolant-cooled exhaust turbocharger
  • Mechanical coolant pump
  • And electric coolant pump
  • Characteristic map thermostat
Due to the twin-scroll technology, the B46 engines are equipped with a steel manifold. 'Twin-scroll' means that the exhaust flows are routed via two separate channels to the exhaust turbocharger. The heat produced is absorbed by the coolant which is supplied via a coolant connection on the exhaust turbocharger. When the motor is not running, post-cooling of the exhaust turbocharger is possible with the assistance of an electric coolant pump. This prevents a build-up of heat in the area of the exhaust turbocharger.
Water pump / coolant pump
The coolant pump is a single unit also containing the thermostat. The coolant pump housing is made from the aluminium alloy ALSi9Cu3, the impeller and the thermostat cover are made of plastic. The DME controls the cooling circuit via a map-controlled thermostat.
Lifetime coolant
The coolant is not subject to a change interval, the factory coolant is designed for the entire service life of the engine. Work which requires an opening of the cooling circuit, coolant must be replaced as needed. The cooling system must only be filled with BMW-approved coolant. If the wrong coolant is used, damage to the coolant pumps, coolant hoses, radiators and cylinder head gasket may occur.
Turbocharger
P90143708_highRes by Ryephile, on Flickr
The exhaust turbocharger of the B46 engine is a twin-scroll exhaust turbocharger. To facilitate a fast and direct response, the exhaust flows from cylinders 1 and 4, and 2 and 3 are merged and routed to the compressor via two separate channels. This principle is referred to as pulse turbocharging. The exhaust manifold and exhaust turbocharger housing have been designed as one common cast part and cannot be replaced individually. The charging pressure in B46 engines is controlled via an electrically adjustable wastegate valve.
Blow-off valve
A blow-off valve is not used in current models. Pressure peaks, caused by sudden load shedding due to the inertia of the turbine of the exhaust turbocharger, can be avoided by careful tuning of the Digital Motor Electronics software. With foresighted charging pressure control, pressure peaks can be predicted and reduced by quick adjustment of the electrically-adjustable wastegate valve. Assisted by a delayed load control of the Valvetronic (in the minimum lift direction) or the throttle valve (in the closed direction), the remaining charge air which is produced can be routed to the exhaust emission system via the engine. This form of control thus prevents the exhaust turbocharger shaft from being exposed to excessive torsional stress due to high pressure peaks.
Wastegate rattle
Apparently BMW is fine with a little wastegate rattle at startup. They state if the wastegate valve is opened when cold, pulsation of the exhaust gas may cause vibrations in the wastegate valve, which are perceived as noise. This is not due to a defective component, and is normal running noise. This noise becomes less audible as the temperature of the component increases.
Fuel System
BMW B48 fuel system HPFP fuel rail by Ryephile, on Flickr
The main high pressure fuel pump (HPFP) is a single-piston high pressure pump by Bosch, similar in concept to the unit on the N20/N55. At this point BMW seems to have resolved all HPFP failures so there should be no concerns about that. The high pressure pump is driven by a triple cam which is attached to the exhaust camshaft. Fuel low pressure is supplied to the high pressure pump via the fuel feed from the in tank electric fuel pump.
The direct rail represents a departure from the familiar systems used up till now. With this system, the high pressure lines have been omitted and the injectors are attached to the rail directly.
Directly connecting the solenoid valve injectors to the rail has the following advantages:
  • Less volume needs to be available for high-pressure injection
  • Fewer interfaces and therefore less problematic with respect to leaks
  • Short cycle times during production due to compact design
BMW B46 engine - transmission side by Ryephile, on Flickr
BMW B46 engine - side view by Ryephile, on Flickr
BMW B46 engine - Belt view by Ryephile, on Flickr
Here are some extra pictures from BMW's B38/B48 press release event. This is a picture of the engine cutaway showing the piston crown and skirt. Note the broad piston crown "bowl", this is where the combustion flame kernel occurs. Also a picture of the Valvetronic servo and camshaft cutaway.
P90143710_highRes by Ryephile, on Flickr
P90143704_highRes by Ryephile, on Flickr
Cheers,
Ryan
Old Oct 15, 2015 | 12:58 PM
  #34
caiken's Avatar
caiken
Great stuff.
Old Oct 15, 2015 | 04:57 PM
  #35
alexmini08's Avatar
alexmini08
Couple of questions!!! I know that someone may help me on this...
-If "A blow-off valve is not used in current models", from where do we get the typical BOV sound (which for me come from the passenger side of the engine)?
-Also, my air filter comes with a foam pad (can I remove it?)
-Does anyone noticed that the stock airbox comes with a "check valve" on the back, that draws hot air from the engine? Any idea of the purpose of it?
-What about the bigger tube in the intake pipe?? to change the air pressure before entering the turbo? Something to do with the PVC lines???
Thanks!!!
Old Oct 15, 2015 | 05:24 PM
  #36
Ryephile's Avatar
Ryephile
I'm not sure where the sound is originating. The lack of a diverter aka blow-off valve is actually news to me.
Foam pads on air filters are usually used in abnormally dusty or frosty areas. Given your area, neither sound applicable.
Does your airbox innards look different than my picture on the previous page?
Lastly, the large cross section of the intake pipe from the airbox to the turbo is a resonator to minimize induction sound into the cabin. It's also where the PCV lines enter, however that's just coincidence.
Hope that helps!
Old Oct 15, 2015 | 05:46 PM
  #37
alexmini08's Avatar
alexmini08
Hope that helps!
Thanks for the help!!
Yes, my airbox is different. I'll take pictures as soon as I get home. As for the foam, I'm from Puerto Rico, so snow its not a problem, dust? Maybe... But I also vacuum the filter regularly (Every two weeks) and I will replace it later on with a K&N or anyother drop in... Its going out! As for the intake respnator, I've been thinking of making a good quality replacement tube to try to get more sound from the turbo, its extremely quiet... ***I'm not expecting to get a huge amount of sound as the turbo is quite small, but something is better than nothing...***
Old Oct 15, 2015 | 07:45 PM
  #38
alexmini08's Avatar
alexmini08
Inside of Airbox with division..
Hot air duct
Opening where the valve goes
Checkvalve
Old Oct 15, 2015 | 08:25 PM
  #39
Ryephile's Avatar
Ryephile
Oh that is quite different. I also haven't been able to find it in RealOEM database. I can't think of a good technical reason to inject hot air into the airbox, or why there would be a check valve there.
As for the turbo sound, for sure you can get more compressor sound by removing the intake muffler and resonator, but just for the record the size of the turbo doesn't dictate its loudness, however it does typically affect its pitch as smaller turbos typically spin faster. The turbo in the Cooper S and JCW aren't small unless you're used to a GT35R being average-sized, which would be a fairly skewed perspective in an OEM context.
Cheers
Old Oct 15, 2015 | 10:22 PM
  #40
alexmini08's Avatar
alexmini08
Cheers
I'm taking the check valve off and blocking that inlet for the same reason. I know that the compressor isn't small, I just don't want to set a high expectative, as this engine (from my perspective) has been design with a more "sleeper" approach... More power, but also more "sound comfort". BTW! There is a type of solenoid valve in the first PCV hose that connects to the inlet pipe. Im checking that out to see if that could be the "noise generator". Lets hope that nothing breaks!
Old Oct 19, 2015 | 06:37 PM
  #41
Ryephile's Avatar
Ryephile
I did a little bit more datalogging tonight. Here is a graph proving that the full load power is identical between Green, Mid, and Sport modes. To be specific I set the cruise at 70 mph, then on a level section of road I floored it as quickly as possible, letting the engine pull through 80. It ends up being a short datalog, but quite insightful. I did the same 70 to 80 pulls, starting with Sport mode, then Mid, then Green, and back to Sport [labelled "Sport2" in the chart]. I chose to only show three sensors to streamline the graph. The notable thing I left out was Air Fuel Ratio, because the measurements were literally identical to the hundredth of a Lambda. The beginning of each pull was 1.0 Lambda, and they all ended exactly at 0.97 lambda. Also, Coolant Temps were between 219-221F, and Oil Temps were between 206F and 210F for this exercise.
Please don't look too hard at the graph in terms of deviation, as they're not be matched up perfect on a time scale. OBDII only allows for a certain refresh rate, and the more sensors you choose the slower the rate between each sensor poll. What we're looking at here is the Manifold Absolute Pressure (Boost), Mass-Air Flow rate (Horsepower), and Ignition Timing as a sanity check. The RPM band of the pulls is 2900 to 3300 RPM, fairly narrow, however well within the meat of the torque curve.
Screen Shot 2015-10-19 at 7.37.34 PM.jpg by Ryephile, on Flickr
Just for fun, I simultaneously ran the MINI Connected Sports Instruments showing HP and LbFt, further corroborating that 10 Lb/Min approximately equates to 100 HP. As such, 14 Lb/Min at 3000 RPM is about 140 HP, and subsequently 140=[LbFt*3000RPM]/5252 = 245 LbFt. And 15 Lb/Min at 3300 RPM is about 150 HP, and subsequently 150=[LbFt*3300RPM]/5252 = 238 LbFt, both of which reasonably match the 240-ish LbFt I observed on the MINI Connected display.
I also took some datalogs of me trying to hold the throttle pedal angle steady as I toggled through the 3 modes, but I haven't filtered through that data yet. Just for reference, the throttle pedal "D" is the correct PID for your foot pedal, and it's about 14% at closed and 81% at "full throttle".
Old Sep 19, 2017 | 05:26 AM
  #42
jpbarrett's Avatar
jpbarrett
I'm new to this website, so I apologize for this (what may be a)simple question. I was having what I thought may have been a leak in the coolant about 2 weeks ago. After 6 people(including a MINI service center) looked at it, shuffled things around, the coolant no longer was leaking. No one could find a leak. BUT, after all of that was done, I found this hose/pipe laying in the same area that was being inspected by the above 6 people. It was just laying there, not connected to anything. I texted this picture to a friend, and he thought it may have something to do with the emission system. After some surfing on the web, it looks a lot like an emission vent pipe. But I'm not sure. So the first question is, what is it? the second question is, where does it go?
Old Sep 19, 2017 | 05:27 AM
  #43
jpbarrett's Avatar
jpbarrett
The whole thing
Closer look one end of the pipe
Closer look of the other end of the pipe
Old Sep 20, 2017 | 05:29 AM
  #44
nqr31467's Avatar
nqr31467
Great thread!!! Tons of helpful information.
Old Jul 18, 2019 | 10:44 PM
  #45
@#M's Avatar
@#M
Good day
Great expansion on the under the bonnet piece. Please help out with the wastegate actuator, I know the canister comprises of the back side that absorbs pressure and the front side is filled with a spring to erect the rod.. What happens if there is a crack or the back side is torn, my assumption is that the wont be a power boost, however with my experience it begun with low boost and came up with drivetrain, drive moderately message and just decided to kick in and its over 8 months and still going.
Old Aug 16, 2024 | 06:44 PM
  #46
2019 mini all4 s's Avatar
2019 mini all4 s
Removed cover because of cam shaft codes to see where things were and found this wire unplugged. Can’t find the location to plug it back in. Cam shaft bank1 over retarded, cam shaft b stuck type codes. Assuming it’s because of this unplugged. Please help. 2019 mini countryman all4 s
Old Aug 18, 2024 | 04:56 AM
  #47
Stu-mon's Avatar
Stu-mon
everyone should go to Mini & get their BUILD SHEET & VIN # SHEET - SAYO wanna find out if you're B46 or B48 ?
Old Aug 18, 2024 | 05:06 AM
  #48
Stu-mon's Avatar
Stu-mon
go to Mini & get your BUILD SHEET & VIN # SHEET
USA-RET
E-Mini (2020+)
Jun 20, 2020 07:40 AM
mk1leg
Classic Mini Talk
63
Sep 19, 2016 01:35 PM
Papote
Electrical
Nov 8, 2013 03:28 PM
JT-KGY
May 31, 2007 05:30 PM
blacknblue
MINI Camera and Video
Jun 8, 2005 04:50 PM
