F55/F56 Bad air smell
Old May 28, 2015 | 06:36 AM
  #26
JohnBLZ's Avatar
JohnBLZ
Anyone have the TSB # on this? Mine has gone from the occasional smell to it being every time I fire up the car in the past week or two.
Old May 28, 2015 | 11:03 AM
  #27
hp79's Avatar
hp79
I have this weird smell too but I almost never use AC. Could it still be coming from the evaporator? I also coded so that the AC doesn't turn on with automatic climate control.
I'm afraid if I take this to the dealer, they will just say "oh, that's a normal behavior", like always.
Old May 28, 2015 | 11:44 AM
  #28
hammerhands's Avatar
hammerhands
I would appreciate the TSB# as well.
Old May 29, 2015 | 09:15 AM
  #29
MINIwuff's Avatar
MINIwuff
It is most definitely not normal behavior. The drain tube for the evaporator cannot sufficiently handle the load and it backs up and soaks the foam around the evaporator causing the smell after some time. I believe that the design was changed for the 2015 model, but the change could have happened after some 2015 models were built. Definitely check with your MINI Service department. It is a pretty involved repair (removing most of the dash) and it will only get worse if not addressed. I have a 2015 and have not had the issue, but living right on the ocean, I rarely use my AC as well.
Old May 30, 2015 | 01:17 PM
  #30
wtwien's Avatar
wtwien
I do have a 2015 which was built in week 27 and I do have the problem of the bad smell.
Old May 31, 2015 | 03:24 AM
  #31
Rajapruk's Avatar
Rajapruk
My sunroof smells really bad when open. I think it is the grease or something.
Old May 31, 2015 | 01:13 PM
  #32
mopar2ltr's Avatar
mopar2ltr
Bad air smell
Add another one to the list I am taking mine in tomorrow for an evaporator replacement due to foul odor when first turning on the AC it is a 2015 MCS F56 with auto air they will have the car for a few days. Even though it is inconvenient to have to take the car in for repair the dealer has been Amazing I do not mind having a loaner for a few days plus it gets detailed for free 😎
Old Jun 1, 2015 | 09:37 AM
  #33
trwxxa's Avatar
trwxxa
Or you need to move to a less smelly place.
Old Jun 4, 2015 | 06:06 AM
  #34
JohnBLZ's Avatar
JohnBLZ
Anyone nail down the TSB or part # for this?
Old Jun 4, 2015 | 06:36 AM
  #35
mopar2ltr's Avatar
mopar2ltr
Part number
I will have to check my paperwork I just picked up the car last night . They had to replace the evaporator the smell seems to be gone it only took one day for the repair
Old Jun 4, 2015 | 11:04 AM
  #36
JohnBLZ's Avatar
JohnBLZ
Thanks! please do!
I have to hang my head out the window when I start up the MINI every morning... smells like week old dead animal
Old Jun 5, 2015 | 04:26 AM
  #37
mopar2ltr's Avatar
mopar2ltr
part numbers
The dealer replaced the following
64-11-9-321-875 Microfilter/activat
64-11-9-297-761 Gasket Ventilation
64-11-9-297-744 Bare Housing heater
64-11-9-262-789 condensation - water
64-50-8-374-959 Gasket ring
64-53-8-375-742 Gasket ring
They did not list a TSB number, they knew the issue as soon as I mentioned the symptoms it has been a few days since the repair and no more smell
Old Jun 6, 2015 | 09:09 PM
  #38
JohnBLZ's Avatar
JohnBLZ
Thank you!!
Old Jun 27, 2015 | 11:44 AM
  #39
brian.dayton's Avatar
brian.dayton
My 2015 F56 is in the shop right now. It's on day two and I got a chance to see the car in the shop with most of it's guts yanked out. Dash was on the ground and several parts strewn across the interior. Really hope it all goes well, looks like major surgery to get to this evaporator. All this and my first oil change service.
Old Jun 27, 2015 | 04:04 PM
  #40
hp79's Avatar
hp79
I was thinking the same thing. I don't have a sunroof but I smell something every tine I open the window and turn off the fans. I was thinking maybe an adhesive from the ceiling or weatherstrips.
I did get my evaporator taken care of by my dealer, but now there's a big scratch/scuff mark on my handbrake. Dealer was great by the way. I'll probably have to take it in again to get a replacement handle.
Old Jun 27, 2015 | 07:35 PM
  #41
TX1911fan's Avatar
TX1911fan
Just got mine done. Called and explained the problem. The Service Advisor knew exactly what I was talking about. Made an appointment, got a loaner for a day and now it's fixed! So nice to have my new car smell back.
Old Jul 8, 2015 | 06:36 PM
  #42
At DiiSign's Avatar
At DiiSign
I've got the same problem
Originally Posted by minipumpkin
Hi all,
Does anyone have any problems with the air smell? I took my 2014 hardtop in 3 times, and currently it's in there again for this issue. They contacted mini USA twice about this and still no fix. I was thinking about lemoning my car, but not sure what the process is in Florida or if it's even worth it.. Help!
Its been 3 times already on my car. My car is also mini cooper hardtop 2014, my lemonlaw will be expire on this september. U wanna lemon them with me? It would be better if we have witness or something. I'm in tampa, florida and i usually go to wesley chapel branch. Let me know if you think the same way.
Old Jul 9, 2015 | 09:28 AM
  #43
JS24's Avatar
JS24
If your car has been to the dealer three times what exactly have they done to fix the issue? 100% it is the evaporator. So if they have not replaced that, the smell will not go away.
Old Jul 13, 2015 | 06:26 PM
  #44
At DiiSign's Avatar
At DiiSign
well,
Old Jul 13, 2015 | 06:28 PM
  #45
At DiiSign's Avatar
At DiiSign
they've changed the evaporator to the newest one, but it is still have the smell. My car is now at the dealer to change to the upgrade another newest one again. That's what they said.
Old Jul 14, 2015 | 09:55 AM
  #46
JohnBLZ's Avatar
JohnBLZ
Had to replace the heater core in mine. Had a loaner for a week..
Old Jul 16, 2015 | 06:14 AM
  #47
MRM69's Avatar
MRM69
Great thread! Wifes 2014 MCS started stinking BAD
Calling service department now for repairs
Old Jul 21, 2015 | 10:19 AM
  #48
BoCRon's Avatar
BoCRon
Friend just took her '15 F55 S in to the dealer. They told her that her May build missed the cutoff for the bad evaporator so she should have the new evaporator. They aren't sure what they should do since the "new" evaporator shouldn't have the problem.
I'm wondering how they know it's the new evaporator as they haven't pulled the front off the car yet?
I told her to tell them we'd read it was build up through the end of May.
Sigh,
Old Jul 25, 2015 | 07:05 AM
  #49
CooperB's Avatar
CooperB
The evaporator is behind the dash -- I don't think they have to pull the front off.
Just got my May 2014 build Cooper S replaced this past week. I was talking to the tech about some other items and he said it was a royal pain to replace. They have to drop the exhaust as well to access the drain line from the evaporator.
I don't have the TSB # but on my paper work it shows MINI campaign SIB-64-02-14; Remove and replaced evaporator, replace micro filters, check drain fittings, recharge A/C system.
Old Jul 25, 2015 | 07:17 AM
  #50
lefty1630's Avatar
lefty1630
I have a 2015 4 door hardtop and had a bad smell prior to the AC starting. Dealership said no problem where they replaced the heater box and microfilters and problems went away. My adviser said that they have done this to three other vehicles.
Hope this helps
