F55/F56 Power brakes -- how?
Old Oct 8, 2014 | 02:19 PM
Lawnmower3000's Avatar
Lawnmower3000
Valvetronic has an interesting side-effect in that there's no "vacuum" in the intake manifold nor is there a traditional throttle plate that would cause a "vacuum". In fact, the intake manifold is always at some positive pressure due to the turbo. For performance and responsiveness, this is a Very Good Thing. But that got me thinking about the brakes. After a bit of peering through some small openings in the plastic ocean under the hood, I was able to identify what sure looks like a common vacuum-operated brake booster. If that's right, how do they do that? Or, possibly it operates on positive pressure, but that wouldn't seem so reliable since it wouldn't have much working pressure at idle.
The only remaining possibility that comes to mind is that they've added a separate vacuum pump just for the brakes. Could be engine-driven or electric.
Anyone know how this actually works?
Old Oct 8, 2014 | 02:40 PM
allhailpoptart's Avatar
allhailpoptart
My 95 Audi S6 (inline 5 cylinder turbo) uses a pressure accumulator system (referred to as the 'bomb' since it looks like one from the cartoons) that is driven off the hydraulic system pump. Pressing on the brake pedal then actuates a switch that lets pressure out of the accumulator and into the lines to provide the stopping power.
This all looks like a normal setup if you were just looking at it from the top down. It has a normal looking ABS booster and what not. Mini may be using something similar. I'm sure someone with access to ETKA or similar can confirm.
Old Oct 8, 2014 | 02:59 PM
Lawnmower3000
Nope. There is no need for a hydraulic system because steering boost is electric. Which, BTW, seems to work very well.
Old Oct 8, 2014 | 04:44 PM
Benibiker's Avatar
Benibiker
Hello? The op is asking about power brakes not power steering. Bet it's electrically driven though.
Old Oct 8, 2014 | 10:35 PM
dwdyer's Avatar
dwdyer
Whatever system is used it could use beefing up. I still think the brakes are a bit soft.
Old Oct 8, 2014 | 11:03 PM
bmwr606's Avatar
bmwr606
there is a vacuum pump on the engine
Old Oct 9, 2014 | 03:22 AM
Lawnmower3000
Thanks for clearing this up.
Old Oct 9, 2014 | 06:15 AM
George 2014's Avatar
George 2014
I have no complaints with the brakes except to say that it will be nice once some options as far as aftermarket pads start to open up for the F56.
Old Oct 9, 2014 | 08:42 AM
Diana De Van's Avatar
Diana De Van
Absolutely agree - inferior to my last car (Golf GTI) which was a step down from my 2012 MX5. Hmmm only weak spot on the car!
khumpert
Nov 30, 2015 11:48 AM
theblackfalcon
Oct 11, 2015 09:49 AM
HaveATank
Sep 4, 2015 08:04 AM
HaveATank
Aug 24, 2015 10:26 AM
