F55/F56 First gear tops out
Old Aug 11, 2014 | 06:03 AM
  #26
George 2014's Avatar
George 2014
Getting back to the whole rpm control-thing, what it felt like to me when it happened was not so much that the motor hit a rev limiter as much as it hit boost cut. Again, I could be totally wrong about this since I have no clue how Mini programs their ECU's but generally speaking, when you hit the ECU's rev limit, the motor does not just stop (as it did for me...). Generally, the engine continues to run and usually "bounces off the tach" at that point, until you lift out of the throttle.
On boosted motors, there is often a safety feature called "boost cut" or "lean cut" that actually stops fuel flow to the injectors. That, of course, stops the motor altogether. That's what it felt like to me. Not hitting the rev limiter. Just my observation.
Old Aug 11, 2014 | 09:14 AM
  #27
hammerhands's Avatar
hammerhands
p.74
Tachometer
Always avoid engine speeds in the red warning field. In this range, the fuel supply is interrupted to protect the engine
Old Aug 11, 2014 | 09:38 AM
  #28
George 2014
Well, there we have it: Fuel cut.
Old Aug 11, 2014 | 02:31 PM
  #29
Blumperkan's Avatar
Blumperkan
Does no one over here understand gear ratios? At 40 MPH in first gear, your engine would be at 7,500 rpm... The engine does not want to do that.
Old Aug 11, 2014 | 02:42 PM
  #30
Mrdi's Avatar
Mrdi
Old Aug 11, 2014 | 04:16 PM
  #31
hammerhands
http://www.miniusanews.com/pdf.do?&id=608
My math says 7500 rpm sounds about right for the Cooper S.
Old Aug 11, 2014 | 05:13 PM
  #32
MINIAC's Avatar
MINIAC
F56 MCS specs state peak (189) horsepower is maintained from 4700 - 6000 RPM. Is redline 6000?
Old Aug 11, 2014 | 05:15 PM
  #33
Mrdi's Avatar
Mrdi
Red shows above 6400 RPM on the F56 tach.
Old Aug 11, 2014 | 05:18 PM
  #34
Mrdi's Avatar
Mrdi
Originally Posted by Motomama
Anyone else have issues with first gear loosing acceleration around 40 mph? I am forced to shift to 2nd. This is a totally different feel, than in my R56.
Don't know, if this is something everyone experiences, or just me. I don't drive like this all the time, but it's annoying, while having fun with other drivers.
Was this thread started by a Bait Fisher?
Take a look.
40 in first?
I can beat any car in my Mini?
First thread started by Motomama.
The hook is barbed.
I smell Troll.
09R56
Nov 16, 2022 10:49 AM
MiteyF
Aug 26, 2015 05:07 PM
tacticalbacon02
Aug 22, 2015 06:05 PM
Aug 12, 2015 01:24 PM
