F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
F56 crank pulley failure
Old Oct 6, 2021 | 10:04 PM
MattW's Avatar
MattW
Hi All. I was driving and had a battery not charging alarm shortly followed by an engine temp alarm. Found that the belt was in place but not spinning. Pulled the inner guard out to look at the crank pulley, started the car and the inner part of the pulley was spinning and the outer part including the belt does not spin. Is this fair evidence that the pulley is faulty? Also, I can spin the outer of the pulley which includes the belt, quite freely. So I assume none of the belt equipment is putting undue strain on the pulley.
what actually gives way in the pulley? It doesn’t look like an old school pulley with a fair bit of rubber within it….
Attached Thumbnails F56 crank pulley failure-7638d498-ff9f-4105-9b7f-8d024cb2bba7.jpeg
File Type: mov
Old Oct 7, 2021 | 05:22 AM
renchjeep's Avatar
renchjeep
I would say that you have found your failure point. It looks like the rubber isolator ring on this particular harmonic balancer is just not as visible as the ones we are used to seeing. I am thinking it's somewhere behind those 5 elongated slots, hiding inside the assembly itself.
elightbo
Jun 4, 2017 04:39 PM
boholio
Jan 4, 2016 08:05 AM
niquemarshall
11
Jan 14, 2012 09:43 AM
qwertmonkey
Jul 26, 2006 09:18 AM
meb
Apr 24, 2005 01:26 PM
