F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
Sunroof Screens Rattle
Old 09-12-2018, 08:40 AM
EnjoyRC's Avatar
EnjoyRC
EnjoyRC is offline
I have found that if I open either, the front, or the back sunroof screen, they rattle against the frame. I need to open all the way, then back about 1/2".
Is this common?
Old 09-12-2018, 09:14 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Minnie.the.Moocher is offline
Works that way on mine. If you go to the dealer and complain, they will probably put some cushioned velvet like tape on it to keep it from rattling in the closed position. I didn't bother with that, I just keep it backed off a bit.
If you have no squeaks or rattles, then you don't have a MINI.
Old 09-12-2018, 10:55 AM
JasonMa's Avatar
JasonMa
JasonMa is offline
Same thing here. Once I figured out that backing it off just a tiny amount solved it I didn't bother worrying about it anymore. If I forget and hear the rattle I can just reach up and move it slightly.
Old 09-12-2018, 03:34 PM
whitesilvermini's Avatar
whitesilvermini
whitesilvermini is offline
I too noticed this and went with a very thin piece of sticky back black foam in the middle of both.... seems to have done the trick.
Now if I could only get the passenger door HK speaker trim to stop I would be golden.
Cheers,
John
Old 09-13-2018, 04:31 PM
lostronin's Avatar
lostronin
lostronin is offline
Yeah. When I complained to the dealer they fixed it with cushioned tape. Sweet silence ever since.
Old 10-16-2018, 10:26 AM
F56mini's Avatar
F56mini
F56mini is offline
Mine does this too. Mostly the rear, I just open it to a place where it stops. Looks like foam tape is the answer.
Old 11-28-2018, 05:25 PM
Myfast's Avatar
Myfast
Myfast is offline
Try removing the speaker trim and apply thin slices of dynamat or equivalent, this will increase its weigth and make it less prone to vibrations, additionally, if you could insert tiny pieces of foam you weill be done for sure. Can you post a photo of where did you apply the the foam on the sunroof?
Old 11-28-2018, 05:49 PM
Kowboycoop's Avatar
Kowboycoop
Kowboycoop is offline
Yep even my 2017 F60 Country Man rattles I just readjust the Sunroof screen a few inches and it stops. Annoyed yes, But at this time im dealing with it.
Old 12-02-2018, 11:56 AM
TVPostSound's Avatar
TVPostSound
TVPostSound is offline
Cheers,
John
Its the trim directly to the rear of the speaker.
Ditto here!!
Old 12-03-2018, 10:49 AM
ECSTuning is offline
Received 1,965 Likes on 1,765 Posts
Back in the day MINI used the felt side of the velcro tape, i have done dashes, speakers, and panels in my MINIs with this stuff
Old 12-15-2018, 05:34 PM
Myfast's Avatar
Myfast
Myfast is offline
Question
Cheers,
John
Could you please upload a photo of where to put this tape? This rattle is driving me nuts.
Old 12-18-2018, 10:13 AM
whitesilvermini
Sunrrof Screen RAttle Fix
Howdy Myfast,
Sorry for not posting sooner and hopefully this helps you with your rattle.
I have placed the sticky back thin foam piece at the point where the screen handle contacts the trim frame around the roof opening.
It is placed on the fixed portion of the frame at the point where the centre of the screen handle lies when fully open (the only time I had a rattle is when the screen was open). This is where I found enough contact for the foam to stay in place.
Myfast (12-18-2018)
minibbb
05-27-2013 09:27 AM
enjoyingsilence
08-29-2008 01:16 PM
Electron_Mike
08-05-2004 10:29 PM
tsprayfhs
05-19-2004 02:24 PM
kenxtl
06-25-2003 08:55 PM
Quick Reply: Sunroof Screens Rattle
