F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Coolant level clubman 2017
Old Oct 22, 2018 | 05:24 AM
Zoya2016's Avatar
Zoya2016
Please can somebody explain coolant level on coolant tank. I can not notice any low, hi marks except some horizontal lines. Thank you .
Old Oct 22, 2018 | 06:23 AM
G26okie's Avatar
G26okie
Not sure if its the same as the f56, but to check the coolant level the indicators are inside the tank. You need to open the cap and look inside for the MIN/MAX. Obviously only when the engine is cold.
Old Oct 22, 2018 | 08:36 AM
1200K's Avatar
1200K
It's the same -- the MIN/MAX markers on my F54 are located inside the tank, requiring removal of the cap and a look inside to determine the tank's coolant level.
Old Oct 22, 2018 | 09:19 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Owners manual is the go to source.
Old Oct 22, 2018 | 01:24 PM
gearhead60's Avatar
gearhead60
From: Manassas, VA where the Civil War resides.....
There's coolant in my car?
Old Oct 22, 2018 | 10:33 PM
Lefooey's Avatar
Lefooey
Better in your car than on your driveway!
Old Oct 23, 2018 | 10:42 AM
WhatV8's Avatar
WhatV8
The wonders of modern technology, don't forget to check your muffler bearings on occasion...they are not lifetime like most auto mfg's will lead you to believe. Some great advice can be found here:
Ok, back to our regularly scheduled topic...
Old Oct 23, 2018 | 01:20 PM
gearhead60's Avatar
gearhead60
Muffler Bearings
The level of expertise on this forum is the best bar none! I've scheduled an appointment with my service advisor to make sure mine are still in good condition. Thanks!
Old Oct 31, 2018 | 09:59 AM
2017All4's Avatar
2017All4
Super Moderator
Wink
Carbon Fiber Muffler Bearings are a great, but expensive, upgrade. On the F54 you can test the bearing tightness by using the kick open feature for the rear doors. But it must be done in a public area with people watching and the bearing test only works if you get both doors open on the first try.
An alternative is to have the key fob in your jeans pocket and activate the rear door opening feature when accelerating from a stop light. If all the stuff in the boot dumps out onto the street and the doors are open, if you don't notice that this has happened, it means you don't have excessive muffler bearing noise and everything's okay.
These cars are engineering marvels, indeed .
Old Nov 2, 2018 | 10:12 AM
gearhead60's Avatar
gearhead60
You just can't make this sh*t up!
Old Nov 2, 2018 | 05:49 PM
2017All4's Avatar
2017All4
Super Moderator
Yup. As they say, "Truth is stranger than fact"
bugzy
Southern California
Apr 10, 2017 10:24 AM
ModInJapan
Southern California
Jan 24, 2017 01:50 PM
cowleyworks
Jan 18, 2017 05:50 PM
hyperblue1
Jun 26, 2005 07:17 PM
sickmodboy
Dec 10, 2002 06:57 PM
