F54 FYI -- coding rear fogs to act as brake lights
2017All4 (10-19-2017)
Note: I have factory rear fogs which makes it very straightforward.
Thats what I was wondering?
Just checked. The rear fogs work exactly as before. If they are on, nothing happens to them when you brake- only the original brake lights will light.
on
It's been done using Bimmercode as well!!
See post #6 on:
https://www.northamericanmotoring.co...rcode-app.html
I'm hoping, but not optimistic, that Carly will add this as well.
See post #6 on:
I went the other direction and coded my “running” lights to work as brake lights instead of the rear fogs.
Keep in mind it only works if you don’t have the headlights on. However, I’m still looking to see what deeper ECU values I can dig into (I’m pretty fluent in German and hexadecimal)
Keep us updated!
I hate my brake lights!
Ok, so I coded my fogs to act as brake lights, all is good.
I recently sourced a euro switch that also has the rear fog lights, but can't seem to figure out how to let the car know it's there.
From another post I see:
Activate Rear Fog Lights:
3068 NSL_Verbaut = Verbaut
Code first, then cycle ignition, then restart Bimmercode for the below options
to show up
Activate Rear Fog Lights feature for lighting switch:
3064 Mapping_Nebelschlussl_L_output = nsl_l
3064 Mapping_Nebelschlussl_L_Function = nebelschlusslicht
3064 Mapping_Nebelschlussl_R_output = nsl_r
3064 Mapping_Nebelschlussl_R_Function = Nebelschlusslicht
But when I go into expert, I only see 3067 (LceTmsCoding2) and 3070 (LciMaster) edit: that was in demo mode, doh!
Anyone know how to get this done?
Edit:
Found 3068 in (expert) BDC/LceMaster/NSL_VERBAUT
Found 3064 in (expert) BDC/LceLampMapping3/
And VOILA! Rear fogs!
After NSL_VERBAUT the rear fog indicator worked, but the lights did not until the 3064 nsl_l, nsl_r was activated on the second round.
to show up
Edit:
Johnnyfr03 (07-31-2023)
F55/F56 Rear fogs used as brake lights
Loccusst
05-17-2020 12:32 PM
