Electrical Hard wiring Passport 8500 to Clock Power
I thought I would post the photos of my Passport 850o that is hardwired to the clock.
Passport 8500 hardwired to clock.
Another View of the Passport 8500
The power hookup from the clock - power on fulltime.
Ground hookup, drilled in bracket above the clock.
Power reading of power to clock.
Look at the installation all put back together.
_________________
_________________
>>From what I can figure out,
>>The red/brown wire is the actual power to the clock.
>>The other wire is the power to light up the clock when you turn the key on.
>>I got the same power reading with the key on or off.
MiniRolls,
Neat installation! Bravo! For many years I wired my V1 in various cars off the fuse box looking for wire that was live only with ignition was on, so I could just leave the detector "on" and it would switch on and off with the key. No thinking involved, so it suited me!
Don't have my car yet, but it sounds like the clock is always on; and if I use the lead for the light, I could avoid the PIA fuse box route? And did you add the ground, or just attach to one already there?
Regards,
Red
:smile:
MiniRolls,
Regards,
Red
:smile:
Red, Thank you...
I added the ground. There is a frame member, that has a box mounted to it. I drilled a small hole and installed a small screw. I was worried as there was earlier post about some have a radar dectector hardwired they the installer drilled a holein the roof. This bracket is a good choice.
_________________
_________________
Did wire my V1 today. Wanted to switch it off with the key - tried several times to measure the clock wire - with car started it was showing 12V, but in never worked - finally got peeved and hooked it up on red- constant power. Tried to run the wire under neath the rear view mirror - did not work - when I tried to put the mirror back, some plastic pieces broke off the base and the mirror does not stay firm - will need to replace. Uff, please be carefull, do not repeat my mistakes.
Hooked the V1 bracket on the liner- seems to work great.
>>I added the ground. There is a frame member, that has a bos mounted to it. I drilled a small hole and installed a small screw. I was worried as there was earlier post about some have a radar dectector hardwired they the installer drilled a holein the roof. This bracket is a good choice.
Yesterday I hardwired my Passport 8500 using the instructions and pictures shown in this post. I don't t think I would have tried it without this information. To clear up a few things for others who may attempt this. The mirror comes off easily by twisting it 90 degrees to the left. The clock requires a bit of firmness to remove. Grab it on either side and pull down. And there is a gap between the headliner and the roof which make it easy to fish any wires through. Again, thanks for the info.
>>Is that the smart cord attached next to the clock?
>> Thanks for posting this idea.I think it is a very nice job and gets rid of that dang cord!!
Yes, that is the smart cord, I have the hook part of the velcro on it so it sticks to the headliner. I also made it so when I am drive with my wife I can move the smartcord to the other side and my wife can mute the alarm.
Thanks for the feedback. I really hate dangling cords. I like things in the MINI to be neat and done correctly.
Also, I put a small notch in the clock cover for the cord to come out of and not pinch the headliner.
07-16-2020 12:54 PM
Manny_cooper
09-10-2015 11:09 AM
Navigation & Audio MINI Branded nuvi 360 Installation
Super Coop
08-17-2015 05:09 PM
Navigation & Audio help identifying a couple wires
yashmack
08-15-2015 03:11 PM
