Electrical Looking for switched power fuse to tap
Old 02-10-2010, 11:04 PM
rkw's Avatar
rkw
rkw is offline
Originally Posted by paul_
I also need some connections under-dash (the kit came with a fuse already)
I need to find connections for
a. a constant-on source of power
b. an ignition-switched source of power
c. a dash-light source of power
Do you know how much power it needs? What is the value of the fuse in the kit?
These are 5A switched power sources: F6, F7, F9, F10, F11, F13, F29, F35, F36, F39, F40.
These are some constant-on sources: F23(20A), F28(15A), F32(15A)
Dash light power: Look for a grey wire with red stripe going to the back of any of the components in the center stack (toggle switches, radio, or ventilation controls).
  #52
Old 02-11-2010, 08:20 AM
paul_'s Avatar
paul_
paul_ is offline
The red (accessory power) wire is fused at 5A, I think. I will double check and post again later.
Thanks for the power sources on the fusebox - how should I tap into them with a single wire? Should I use an add-a-circuit type deal, or can I find a wire and tap into it?
The kit I have comes with wire clips that sever the old and new wires' plastic sheath to tap into power (jargon name for this device??).
I would love to find wires that are already fused high enough for the extra capacity and just tie into them that way, short of using an add-a-circuit, which I really don't understand how to use.
  #53
Old 02-11-2010, 08:43 AM
rkw's Avatar
rkw
rkw is offline
Use add-a-circuit. They have a wire coming out of them and you can just tap into that wire using the clip in your kit.
  #54
Old 02-11-2010, 09:29 AM
paul_'s Avatar
paul_
paul_ is offline
OK - any specific circuits I should hop onto? Like I said, I believe the accessory-on is 5A, and the constant on is probably less than 1A considering it's unfused.
  #55
Old 02-11-2010, 10:26 AM
rkw's Avatar
rkw
rkw is offline
Choose any that is unlikely to interfere with what you're using it for. Look at the lists here: https://www.northamericanmotoring.co...nd-wiring.html
  #56
Old 02-11-2010, 08:26 PM
paul_'s Avatar
paul_
paul_ is offline
All sorted! I used F6 I think for the switched power, and whatever the always-on radio circuit is for the constant power.
Add-a-circuits are awesome! The system fired up after finding a decent ground and re-connecting the battery.
The first time though, I almost $*at myself because I tried to turn the car over and everything went dark... Gotta screw that negative terminal back on before you draw so much power
  #57
Old 10-09-2010, 06:54 PM
Nick5811's Avatar
Nick5811
Nick5811 is offline
tl;dr
but,
The left column radio fuse is switched, used it for my PAC wheel adaptor.
Wohnson89
06-10-2020 04:53 AM
siriuszero
09-17-2015 04:41 AM
SolCalMini
08-29-2015 07:25 PM
milkrun49
Factory JCW Talk (2009+)
08-13-2015 06:01 AM
Red Raven
08-11-2015 04:48 AM
Quick Reply: Electrical Looking for switched power fuse to tap
