Electrical Crazy idea for 05 rear fog light mod?
Like others, I am left to ponder about all things MINI while waiting for my car to arrive. I had a thought about the 05 rear fog light and wondered whether it might be feasible.
Is there any way to modify the fog light housing so that it can accomodate two light fixtures? If this were possible, then you can connect one fixture as a backup light, and the other as a brake light. You would use a white lens housing and for the brake bulb use one of those silvered bulbs that lights up red. The result would be that the fog would light up red when you hit the brakes and white when you go in reverse. Heck, with the proper circuit, it could even triple as a fog light (by activating the red light fixture).
All of this depends on whether the housing is large enough to somehow cram in two fixtures. Is there any hope for this to work? I've never actually seen a bumper light housing or know how it mounts.
Originally Posted by rednwhitecooper
that wouldnt be a problem. drill a hole in the top of a clear backup light and add a red light that screws or snaps in and hook that up to your fog light wiring.
Then how about "kicking it up a notch" and getting excessive -- add two extra light fixtures to the housing? A total of three light fixtures: fog, backup and brake. Will it fit and mount okay?
if you were to go dual fillament, you might as well not even use the factory wiring, because the plug wouldnt fit into the new housing anyway!
novel idea, just isnt worth the time!
get 04 tails and use the backup in the bumper and use very bright LED bulbs in the 04 fog location like I did. You need clear tails tho.... (69 bucks shipped on ebay)
on
Originally Posted by rkw
Like others, I am left to ponder about all things MINI while waiting for my ...car to arrive. I had a thought about the 05 rear fog light and wondered whether it might be feasible.
Is there any way to modify the fog light housing so that it can accomodate two light fixtures? If this were possible, then you can connect one fixture as a backup light, and the other as a brake light. You would use a white l...ens housing and for the brake bulb use one of those silvered bulbs that lights up red. The result would be that the fog would light up red when you hit the brakes and white when you go in reverse. Heck, with the proper circuit, it could even triple as a fog light (by activating the red light fixture).
All of this depends on whether the housing is large enough to somehow cram in two fixtures. Is there any hope for this to w...ork? I've never actually seen a bumper light housing or know how it mounts.
Originally Posted by 1FSTMINI
If i read this right.....that would defeat the purpose of a rear fog being the lens is red compared to prior years whiich used a clear one in the same location which was the reverse but is now in the tail lights now.
Wow....thats alot of work for a added 4th brake light......Just to let you know.....You will void your warrenty if anything comes back with you tapping into that wiring harness. I say this being i work for a mini dealer. Just be carefull is all.
on
umm ok smarta55......for one it will void your warrenty if you touch any wire on these cars or any car with a factory warrenty......and just b/c you havent run into a problems yet doesnt mean what your doing is ok with the dealers. Also...What do you think your tapping into when installing an extra light or rear fog........a H-A-R-N-E-S-S cuz being i work at a dealer and should know....if it had one you'd be using it..... wow
Oh, Ok smartass......
For one it will void your warranty if you touch any wire on these cars or any car with a factory warranty. Just because you have not run into a problem yet doesnt mean what your doing is Ok with the dealers. Also, what do you think your tapping into when installing an extra light or rear fog, a H-A-R-N-E-S-S because i work at a dealer and should know, if it had one you'd be using it..... wow
07-16-2020 12:54 PM
12-23-2015 10:36 AM
