Rally Light - IJDM Harness will it work? Wiring Gurus I need some help...
Does anyone know if I use the IJDM harness (Link below) to connect rally lights to the stock fogs if I will have any issues? I am assuming that the Craven Sport Rally light kit that uses the PIAA LP550's have a Deutsch connector (Waiting on PIAA to confirm). I want to be able to eliminate adding another switch and have these come on if I press the stock fog switch.
https://store.ijdmtoy.com/collection...adapter-aa1264 |
I recieved the two harnesses and swapped connectors on the lights. I will post pictures once I get the mounting brackets and know the lights work.
So the harness didn't work. I ended up wiring them with the supplied harness and switch.
https://cimg1.ibsrv.net/gimg/www.nor...2824eee93d.jpg https://cimg3.ibsrv.net/gimg/www.nor...023061d0cd.jpg |
Whats the switch look like? I really like those over the stock ones but *really* wanted to add the factory switch.
Its one of the standard push buttons that come with all the lights. I stuck it on the steering column hidden away. The lights do wire back to the fuse box to an ignition fuse which is cool because you can keep them on all the time and they turn on or off when the ignition is turned on or off. Easy install really good looking too. I got a can of Plastidip and sprayed the grills so they are all black I didn't like the white lettering.
