OEM wiring harness for driving lights
I'm curious . is it possible to buy just the wiring harness for the OEM driving lights. I like Minis switch and harness but would rather use Cibie or Hellas.
Thanks |
Driving lamp wiring
Check out this website, you can make your own:
http://www.danielsternlighting.com/p.../products.html A wiring kit is available from here and other vendors with everything you need to properly install auxilliary lighting. Be sure to install relays, big safety issue. I don't think MINI provides a harness, please correct me if I'm wrong (and I'm sure someone will!). Good luck! |
Go here for a copy of the installation manual which contains all part
numbers. You should be able to order anything you need from any dealer. http://motoringfile.com/howto/Driving_Lights_902.pdf |
