Electrical Front Brake Service reset not resetting
Old May 18, 2013 | 08:19 AM
Papote's Avatar
Papote
I have tried to reset a bunch of times the Front Brake Service reset warning, but it just doesn't want to budge.
I've gone in the Service reset screen and turned off the ignition and gone back in to reset, but when I turn the ignition on it stills displays.
The brakes are still good (no squeaks or anything) and still stops on a dime.
I have a 2008 Mini Cooper S. I have K+DCAN cable, but not sure how to reset it with it. Only used NCSExpert and Dash Commander. Never been able to get ISIS or Carsoft to work.
Old May 18, 2013 | 08:34 AM
Pretje's Avatar
Pretje
Not sure if this is even remotely relevant, but you might check with the dealer. The last time my R56 justa was at the dealer (two weeks ago), it was showing an improper alert for front brakes as well, and it required a software upgrade to resolve it.
Of course, the upgrade also broke the auto-lock feature, but that's another story...
Old May 18, 2013 | 11:40 AM
RobertJ's Avatar
RobertJ
Wait, are you saying that you didn't replace the brake pads but rather they are "still good"? Your brakes have sensor on them that must be replace after it trips the maintenance reminder. You can reset them 1,000 times and it will show right back up again.
If the sensor has tripped the maintenance reminder chances are you probably need to replace your brakes. Yes, the sensor does trip quite a bit of time before you need the brakes, but these Minis run through brakes like nothing I've ever seen for a small car.
You might want to clarify your post a bit and let us know if you've replaced the brakes or not. At 36k miles depending on your driving conditions you're probably due regardless of their squeaking or not. That'd be a good start.
Old May 18, 2013 | 12:32 PM
Papote's Avatar
Papote
I purchased the car used about 3 years ago with 28,000 miles. On my last service, before the warranty gave out, I got the full brake job.
Old May 18, 2013 | 12:35 PM
ZippyNH's Avatar
ZippyNH
The warning comes from Two sources...
The mile countdown AND the physical sensor....if the wire on the pad is cut/dammage, it must be replaced.....you do this when you replace the pads.
Old May 18, 2013 | 03:07 PM
Btwyx's Avatar
Btwyx
The indicator won't reset if the sensor has gone off, even for stage one. The sensor goes off for stage one at about 6mm of pad left, that usually sets the countdown to 6 or 10k miles. Stage two is when the pads get to the minimum spec, 3mm. You may think there's still pad left at that point.
Old May 18, 2013 | 06:36 PM
Papote's Avatar
Papote
Well, I guess I am gonna' have to buy new pads, then.
I've always loved how the Mini stops on a dime. Excellent Brakes!
Any recommendations on good replacement pads?
Old May 19, 2013 | 06:01 PM
richardsperry's Avatar
richardsperry
EBC red stuff... So far o good.
And you need to replace the brake pad wear sensor. That's why the light won't reset.
W0TM8
Dec 19, 2019 07:50 AM
JPMontes3
Aug 23, 2015 01:26 AM
Powershift
Aug 16, 2015 05:14 PM
FLYM1N1
Aug 15, 2015 11:20 AM
