OBDII Codes
Does somone got the complete list of the Mini OBDII Codes, not only the generics ones, there is codes specifics to the Mini
Thanks |
I'm pretty sure all OBDII codes are the same. That's kind of the whole point of OBD is so that there is a standard for engine diagnostics.
Nah there is some special codes look here :
http://www.obd-codes.com/trouble_codes/ There is BMW but not the Mini. |
I believe a pretty complete list of the codes are available in the Bently Service Manual. I remember seeing pages of them when I looked through a friend's copy a couple months ago.
Originally Posted by tirlibibi
(Post 1888885)
Originally Posted by rhubbard
(Post 1889539)
I do not especially need one, i just want to do an OBDGauge update with Mini DTC, if someone can scan me the DTC from the Service Manuel, it's welcome :p
Originally Posted by Motor On
(Post 1892096)
Yes, which one do you need an explination for?
There's a split a bunch of them are indeed common but every manufacturer has their own codes built in as well. Thank you |
