Drivetrain What a 2% Crank Pulley and 16% reduction pulley combo
Old Apr 5, 2007 | 09:47 AM
TobiasMWesten's Avatar
TobiasMWesten
what does a 2% crank pulley add a 16% reduction pulley? whats the 2% pulleyt for?
Old Apr 5, 2007 | 09:55 AM
ChrisW's Avatar
ChrisW
Whats your question?
Old Apr 5, 2007 | 10:04 AM
eager2own's Avatar
eager2own
the combo will provide the equivalent of 18% reduction pulley. The advantage is that the belt has more surface contact with the 16% pulley than if you just got an 18% reduction pulley. . . plus the 2% crank allows you to go from 16 to 18% reduction without changing your 16%, if that's what you already have.
Additionally, manufacturers (like ALTA) claim that the lighter crank pulleys are equivalent to reducing the car's weight by 100lbs.
Old Apr 5, 2007 | 12:38 PM
dmh's Avatar
dmh
Regardless of what a pulley reseller may claim a 16% sc +2% crank is not the same as 18%. It increases the supercharger to crank speed by 21.43%. An understanding of math is critical for tuning!
Old Apr 5, 2007 | 12:59 PM
eager2own's Avatar
eager2own
dmh - thanks for the clarification.
I was basing my response on comments like #814 and #823 on:
https://www.northamericanmotoring.co...=41766&page=33
So, is it your experience that adding a 2% crank to even a 15% reduction pulley will result in increasing supercharger speed by more than 19%?
Old Apr 5, 2007 | 01:10 PM
dmh's Avatar
dmh
All of this is my experience and it is simply math. You can also get it all out of the Bosch Handbook.
15% w/2%=20%
19% w/2%=25.93%
There is more to pulleys than simply installing them. MINI had a good idea of when they made the JCW: it increases the supercharger to crank speed by 16.69%.
Old Apr 5, 2007 | 02:01 PM
ted leist's Avatar
ted leist
I see by the (15% w2%=20% supercharger overdrive compared to stock) and (19% w2%=25.93%) that you are modifying the pulley size based on the effect of belt thickness.
If you consider belt effect, (15% pulley = 17.65% SC overdrive)
(17% pulley = 20.48% SC overdrive)
So a 17% pulley turns th SC slightly faster that a 15% undersized SC pulley
with 2% oversized crank pulley.
I am not positive but I believe that the JCW pulley is 14.8% smaller than
stock. A 14.8% pulley = 17.37% SC overdrive.
15% w/2%=20%
19% w/2%=25.93%
Old Apr 5, 2007 | 02:27 PM
dmh's Avatar
dmh
I measured the JCW as 14.3% smaller than stock. Translation; 16.69%.
Old Apr 5, 2007 | 02:58 PM
eager2own's Avatar
eager2own
the combo [16% + 2% crank] will provide the equivalent of 18% reduction pulley.
Maybe I'm missing something, but it seems to me that this statment is still true. I realize that 18% pulley increases crank speed by more than 18% -- but there's only a negligible difference from running a 16%+2% instead of an 18% (or a 15%+2% instead of a 17%).
Old Apr 5, 2007 | 02:59 PM
JIMINNI's Avatar
JIMINNI
I flunked geometry class . Thanks for the clarification.
ScottRiqui's Avatar
ScottRiqui
An 18% pulley (if there were one on the market) would increase the supercharger speed by 21.95%, which is almost identical to what you get from the 16% + 2% combo.
So, while the advertised percent reduction in size of the pulley is NOT the same as the percent increase in supercharger speed, it *is* true that a 15% + 2% combo will result in almost-identical increase in supercharger speed as a 17% pulley alone. (20.00% versus 20.48%)
Likewise, a 16% + 3% combo will overdrive the supercharger by almost exactly the same amount as a 19% pulley used alone (22.62% versus 23.46%).
Old Apr 5, 2007 | 04:05 PM
Minut's Avatar
Minut
I was told that 2% crank pulleys were not an actual 2% larger, but larger in an amount to be equivalent to a 2% reduction on the original diameter supercharger pulley. Obviously this would still need to be adjusted depending on the actual sc reduction, but not as simple as 2% larger diameter crank pulley. Was this wrong information?
Old Apr 5, 2007 | 05:07 PM
Mr_Q's Avatar
Mr_Q
WOW... they say you learn something new every day! Thanks guys... very good to know!
Doing my install next weekend on the 16% + 2% M7 Kit
vulkandino
Oct 31, 2015 08:29 PM
VanisleRyan
Sep 30, 2015 08:35 PM
dutchhome
Sep 30, 2015 07:17 AM
audio131
Sep 28, 2015 02:21 PM
daviday
Sep 25, 2015 01:31 AM
