Drivetrain I have a question about the clutch engagement point.
Old Apr 14, 2006 | 07:06 PM
krackenthorpe
Hello all, I will hopefully be ordering a MCS JCW this coming week and I have a question about the clutch engagement point. I noticed on the test drive that the clutch pedal travel is looooooong and has a high engagement point. Is there an adjustment to change the travel or engagement point? After seven years of driving a Miata with very short clutch pedal travel and a low engagement point, the MINI is going to take some serious getting use to.
Eric F.
________________________________
Ordering an CR/W MCS JCW very soon
Old Apr 14, 2006 | 09:24 PM
Ryephile's Avatar
Ryephile
You'll get used to it. Go drive a big pile of manual tranny cars, you'll see each one is different. Even different aftermarket clutches for the MINI all feel different!
To answer your question however, there's no adjustment on the clutch [that I know of], as it's hydraulic.
Cheers,
Ryan
Old Apr 15, 2006 | 08:26 AM
dominicminicoopers's Avatar
dominicminicoopers
When I test drove a MINI in late 2002... the engagement point was very close to the floor. When I picked up my MINI in Feb 2003, it's engagement was about the same point.
This took some getting used to since all the cars I am used to driving had the engagement point at the top of the throw.
Then I had my clutch upgraded and the engagement point is now at the top of the throw.
As Ryephile stated, I don't think BMW designed a way to adjust the engagement point.
Old Apr 15, 2006 | 08:59 AM
snooter's Avatar
snooter
Mr. MOTD
I got 2006 MCS, my engagement point seems low. When I know I'm gonna be switching gears, I don't let out my clutch all the way. Is this doing any damage to my car??
Old Apr 18, 2006 | 04:34 AM
krackenthorpe
Thanks for the info.
Eric F.
Old Apr 18, 2006 | 04:56 AM
obehave's Avatar
obehave
Potentially, yes. If the clutch doesn't fully engage the pressure plate you will get premature wear.
You should never rest your foot on the clutch pedal.
Old Nov 19, 2006 | 10:33 AM
ljbusse's Avatar
ljbusse
I've got two 2002 Minis and the clutch engagment points are very different. One is very high and the other is practically at the floor. Which is "right"? Is there any way to make them match??
Old Nov 19, 2006 | 10:36 AM
mbcoops's Avatar
mbcoops
Mine is very low - it's been like that for 45,000 miles. 05mcs.
mb
andrewjg1994
Jan 29, 2021 07:45 PM
eliseo1981
Jan 28, 2021 02:45 PM
Camaro108
Aug 25, 2015 02:44 PM
DiGiPiMP
Aug 24, 2015 11:04 AM
Colt45Magnus
Aug 12, 2015 06:43 AM
