Drivetrain New Helix 15% Twin Cone 380cc injectors
Originally Posted by macncheese
Most newer cars operate under the back of the valve theory but the atomized from the injector was the way to go with things like TBI. The problem with atomizing fuel that far away from the valve is that the high speeds in the intake system seperates the fuel suspended in the flow and the fuel ends up on the walls.
I confess I don't know much about fuel delivery systems, so please bear with me. I will be purchasing larger injectors to solve the pre-ignition pinging problem I have, and I am eager to learn more about the Helix injectors as compared to stock.
Originally Posted by OzMini
Hi Randy, you keep giving us so many new choices to make... so if I have a 15% pulley, opened up air box with drop in foam filter, and your ignition upgrade, should I next go with an improved exhaust or these injectors? How essential would an ECU re-map be at this stage?
My prime motivation is to increase useful (daily driving) power without sacrificing fuel mileage.
Cheers,
Cheers,
I doubt the injectors will do much to improve daily drivng. And yes, to optimize the injectors a new map would be the right way to go.
Interior/Exterior Getting Through the Firewall
papawhiskey
Sep 30, 2015 02:50 PM
dutchhome
Sep 30, 2015 07:17 AM
