Drivetrain 15% Pulley Belt Shredded
Old Mar 13, 2006 | 08:49 AM
RJanke's Avatar
RJanke
I just installed a 15% pulley on my MCS and when doing the initial test drive the outer nub on the belt got sliced off. The car still runs, but I need to replace the belt. When I installed the belt it took a lot of work. After I pulley the tensioner all the way back it still took a lot of prying to get it on. I got the belt with the pulley as a package from MiniMania. It looked to be quite a bit smaller than stock. Does anyone know if it should be easy to slip on or not?
Old Mar 13, 2006 | 08:55 AM
Dr Obnxs's Avatar
Dr Obnxs
If your belt got sliced quickly...
something seems to be wrong. To change the belt, you need to release the tesion with a mini specific tool (although some have made the tool at home with a welder etc).
But make sure that nothing is out of alignment first, or buy two belts in case it happens again!
Matt
Old Mar 13, 2006 | 09:00 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Moved thread from PM-Cooper(non-S) to PM-Drivetrain.
Old Mar 13, 2006 | 09:03 AM
lhoboy's Avatar
lhoboy
Dr. O is right. You need to loosen the tensioner before you r&r the belt. You probably damaged it when you forced on the new belt.
Old Mar 13, 2006 | 09:04 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Also make sure it's routed correctly.
Old Mar 13, 2006 | 09:05 AM
simplygriff's Avatar
simplygriff
Coordinator :: Tar Heel MINI Motoring Club
I thought a 15% pulley didn't require a new belt but instead used the stock one. I thought you changed belts if you went to a 17% or 19%.
I don't have a pulley yet but that's what I've found through a lot of research...
-G
Old Mar 13, 2006 | 09:12 AM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
15% and 17% pulley can get by with a stock sized belt. The belt should have not been hard to put on. They may have send you a 19% belt by mistake. Do you have a part # for it.
Old Mar 13, 2006 | 09:13 AM
conehead's Avatar
conehead
Normally a 15% reduction pulley does not REQUIRE a different belt. Some people use a shorter belt but the stock belt is still within the adjustability range of the belt tensioner. There has been a lot of chat on aftermarket belts having issues as well so try to stay with BMW products on this one.
Old Mar 13, 2006 | 09:48 AM
k-huevo's Avatar
k-huevo
A belt changing technique that is sometimes over looked is to route all of the drive pulleys and save the idler pulley for last because it doesn’t have a lip or lands to interfere with the slide over. Talk about a difficult belt install, the MCSa requires the motor jacked up to get the tensioner tool engaged and the wheel well shroud removed to get the belt on.
Old Mar 13, 2006 | 01:46 PM
lhoboy's Avatar
lhoboy
Great tip, thanks!
Old Mar 13, 2006 | 01:53 PM
RJanke's Avatar
RJanke
Thanks guys I'll just buy an OEM belt. Lots of good information.
Old Mar 14, 2006 | 07:11 AM
garretwp's Avatar
garretwp
As others have asked what was the part number for the belt that the gave you? I know Eric put on a smaller belt for my 17% pulley. I will have to have him show me how to change it when the time comes. Does anyone know of a good way to inspect the belt?
- Garrett
Old Mar 14, 2006 | 08:07 PM
weezer2282's Avatar
weezer2282
I know. I wonder if they have a special tool now for the MCSa, so the techs can change the belt without jacking up the motor. That just seems stupid. It would require the original OEM tensioner tool to be machined down, so it is thin enough to fit down there between the frame and pulleys.
elverado
Jan 18, 2022 02:51 AM
BernieCoop
Sep 10, 2021 03:15 AM
daviday
Sep 25, 2015 01:31 AM
makg
Sep 24, 2015 11:10 AM
Emnotek
Sep 11, 2015 04:16 PM
